Question about Canon PowerShot A540 Digital Camera
Low Batterie Sign
Hai, i have my Canon A540 for like 2 years. Nowadays, my camera keep showing the sign of ' batterie low ' even after I have replace with new batteries. I'm using AA Sony batteries where I bought together with their charges. I did try using new rechargeble AA bateries, but the result is the same.
  • 13 more comments
  • rcase1977 Oct 08, 2008
    I have the same problem
  • Anonymous Oct 13, 2008
    same problem, now the camera hardly works at all, even with new batteries
  • panamaguytoo Nov 01, 2008
    Same thing here. My camera is only 2 years old and it's been doing this for the past year. Have tried other rechargable batteries and that does not help.
  • mmire Nov 06, 2008
    I have the same probelm. I've tried every rechargeable battery out there and still the same problem occurs.
  • Anonymous Nov 11, 2008
    I replaced the AA batteries as well as the watch sized battery. Still looking for a solution.
  • projektbuch Nov 17, 2008
    same problem here - any idea what else to do?
  • twood83 Nov 20, 2008
    Same problem. Can't figure out a solution.
  • Anonymous Nov 30, 2008
    My camera is also 2 years .old and I have been having the same problem for a year
  • nancyr1 Dec 02, 2008
    I can install 2 new AA Batteries and after taking 3-4 pictures the low battery indicator appears and then I can not take any addiitonal pictures. It takes great pictures when I can get it to stay charged :(
  • Anonymous Dec 24, 2008
    Same problem. Even tried Lithium batts with same results.
  • michucatboat Jan 05, 2009
    same problem. fresh batteries, recharged batteries- the all say low battery after 1-3 pictures, rendering the camera useless
  • Anonymous Jan 10, 2009
    I have the same problem. My camera is two years old, and the battery light goes on after taking 2 or 3 pictures
  • valdevers Jan 29, 2009
    The battery low indicator light continues to blink after new batteries are installed. Changed batteries several times and wiped batteries with a soft cloth, problem still exist. After a few minutes the camera shuts off. Can't get very many pictures at this rate. Help!
  • Anonymous Feb 09, 2009
    My camera is also 2 yrs old. All my existing impact/uniross batteries are giving same problem even after full recharge
  • Anonymous May 22, 2009
    I use this camera very rarely as I'm usually shooting with my DSLR. I've had it for three years but have only taken about 100 pictures with it. It's completely useless because I only get about 3 pictures out of high quality, fully charged, batteries. My repair estimate through Canon was $89. I'm pi**ed.
  • 3 Answers
I had the same prolem. OK, try this. Try to discharge the AA batteries in some use, flashlight or else,,,,then recharge them, full charge, install the batteriers ...they should work fine....
I read somewhere that canon is able free of charge to correct a shortcircuit that the camera is susceptible to develop in the installation of batteries......But I hope the advise will work...
Remove batteries when not in use.
Posted on Nov 13, 2008
Canon PowerShot SX110 IS Digital Camera charge fully battery after one pics show low battery sign
This is probably a battery issue and not a camera issue. Batteries with low output or low power can be due to them sitting and not being used for long periods of time. This can affect their ability to get a full charge as their "memory" is reduced regardless of what the charge light indicator displays. Even taking a battery that has been sitting for a long period and charging it to full charge, might only have limited power. Some of these can be returned to almost full capacity, but it takes multiple, repeated, alternating, charges and power deletions to rebuild the memory. In many cases, however, the battery just needs to be replaced.
Feb 10, 2013 | Canon PowerShot SX110 IS Digital Camera
When i turn on my camera with full recharge batteries, it shows low charge battery sign.my camera and batteries are one year old only.what to do?pls suggest.
Hi there if you use much this Camera last one year then its time to change the battery.If not then its a problem of your camera power transformer unit.
Dec 28, 2010 | Canon PowerShot SX120 IS Digital Camera
My Canon Powershot A2000 displays a low battery even when I've just replaced with new. I've replaced several times, each time with two identical batteries, each time from a different package. I may be able...
For the best results, I recommend you to use Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Else......
AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
Feb 11, 2010 | Canon Powershot A2000 IS Digital Camera
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
My Canon power shot S2 IS does not detect the batteries
There is a battery charge level sensor in the DC/DC internal converter board.
It seems that just started to fail such board.
You can try with other brand or type of AA batteries.
If still you have the same problem, you will need to have replaced the DC/DC converter board on your camera. This means a Camera repair shop service on it.
Best regards,
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
I have Canon power shot S2 IS digital camera.I bought it around 2 years back.Now my camera is showing the sign of "change the batteries" even though the batteries are fully charged and the lens does not...
i suggest replacing a fresh battery will most likely solve your prob, overtime rechargeable battery can drain easily, try changing with a new battery and see if it does work well, there might be insufficient current, thats why it tends to drop of voltage easily upon using,
there is a specified lifetime for rechargeable battery, depends on your usage and charging method, theymaybe fully charged but sometimes wont give you enough power to drive
cheers
Does dont....
Try changing the battery. After a year or so of use, any battery goes bad, and needs replacing.
Dec 22, 2007 | SanDisk Sansa c200 MP3 Player
How do u charge battery
well u can't "charge your battery", you have to put new ones in
Sep 09, 2007 | Vivitar ViviCam 3785 Digital Camera
Canon PowerShot A540 Digital Camera Logo
274 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
