Question about RCA 25423RE1 Phone
Intercom won't work
2 brand new replacement phones (Thomson said the problem was with the phone so we exchanged them) and we can't get the intercom to work on these either
    Genius:
  • 1,550 Answers
You have disable paging service on the phone itself. its under regional/phone settings. better yet, delete all the vertical activation codes and service features to no.
Posted on Oct 21, 2008
    Master:
  • 538 Answers
Hmmm..ok...do you have a user guide or manual handy? usually the intercom is an issue with a settings between the phones..
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
AT&T 974 phone intercom button flashing and won't work
1) test the adapter if working with another phone and replace it
2) if working clean the contacts batteries with pencil eraser, and see if working.
3)test the batteries voltage is o.k wit VOM, and replace if necessary
4) test the power supply from the base if is o.k otherwise you must open and repair or go to the repair shop for fix it.
5) Read the owner manual section troubleshooting for help
God bless you
Sep 17, 2012 | Lands Phones
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
Good Morning! I work for a small business that has 5 of the GE 2-9451 4 line phones with intercom. We were actually running two businesses out of the same office originally. Line 1 would ring in to...
Since you said line 3 was working for #2 company, i will suggest you put the line 3 back from where you removed it from. From the look of things the line might be the only line connected to be functioning. When ever you want to switch line since it is with intercom you will need to switch both side from where it is connected to where it is connected to, so that network connection can be achieved.
And on the other hand, the other line might not be working properly, that is why it was not connected or used.
Take care.
Apr 08, 2010 | GE RCA 4-Line Speakerphone
How do use intercom work on rca 2541Re3-a
I have a
RCA Business Phone Model 2541RE3-A How do you get the second wireless handset to comunicate with the Base?
Dec 26, 2008 | Thomson Corded 4-Line SOHO
Phone cord replacement
Any standard phone cord should work no problems.
Aug 20, 2008 | Thomson GE-28115FE1 Cordless Phone
INTERCOM
such B.S. all I needed was how to use my intercom feature and you want to charge me 50 bucks, man that is some kind of **** you have going on there, you should change the site name from FIXYA TO FUKYA
Jun 24, 2008 | Lands Phones
Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Jun 15, 2008 | Siemens Gigaset 4215 Cordless Phone
RED INDICATOR LIGHTS FLASING ON INTERCOM
Thats a common "problem", but its easy to fix. The Intercom lights flashing like that is normal and they will continue to do so until you "assign" the phone its intercom number.  If you have more than one of these phones, go to your other phones, lift the handset and see what intercom number lights on that phone when you do so(the lights/buttons that are flashing). Notate which intercom number that is and move to the next phone. Once you have notated the other intercom numbers go back to the phone you wish to program and push PROGRAM , then push the touch tone key of which intercom number you wish to assign the phone (ie. 1 2 3, etc.), then push MEMORY.  That should do it, and if you need replacements their on Amazon. Good Luck
May 22, 2008 | Dual Handset Cordless Telephone with...
RCA 25423RE1 Phone Logo
328 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
