Question about Hotpoint NLL113EYWO Electric Dryer
Electric dryer switchs is on but drum doesn't turn.
  • 417 Answers
It may be a broken drive belt, check underneath for remnants of the belt.
Posted on Oct 09, 2008
Logik tumble dryer gdz 60-10sw heard clanging noise now dryer still goes on but drum doesn,t turn.
Sounds like the drum has fallen off of the support rollers. Will need to open up cabinet to verify
Jul 04, 2016 | Dryers
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
Dryer lights up but drum doesn't turn. Can manually move drum but difficult.
I would like by your description you have a obstruction in the blower wheel preventing the motor from turning freely. I would seek to find an item of clothes in the blower wheel preventing the motor from turning.
Thats where I would look, I hope this helps
Aug 08, 2011 | Amana NED7200TW Electric Dryer
HOW DO I FIX MY MAYTAG DRYER. IT DOES NOT START WHEN I PUSH
There are a few things that come to mind why your dryer may not start: -Check to make sure there is power going to the dryer -Check that the door switch is working -The motor may have overheated -There may be an electrical fault or loose wire -If the motor turns but the drum doesn't, check that the belt is still on the drum.
For some of these checks you may have to remove the control panel or the front panel. Depending on your skills and experience you may want to have some of these checks done by a qualified professional due to the danger of live electricity.
Jul 29, 2011 | Maytag Dryers
My dryer hums but the drum doesn't turn unless I assist it and then the dryer kicks on. The selector switch automatically turns on when I move from the "off" position (the start switch is...
Hello, Thank You for using FixYa. I will be helping you today.Its the switch in the motor thats bad.Thatmay have been the smell the motor burning up.Replace the motor
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Frigidaire GLER642A Electric Dryer
Dryer not working I replaced the Thermal fuse and still not working.
Is the drum turning? If it's turning, then maybe the high-limit thermostat or element is bad. If drum doesn't turn, check lid switch.
Sep 26, 2010 | Kenmore 74672 Gas Dryer
I push the button to activate the dryer, the dryer makes its usual buzzing noise to indicate it is about to start but it doesn not start
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 03, 2009 | Frigidaire FER211A Electric Dryer
Dryer wil not spin
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 08, 2009 | Dryers
Hotpoint NLL113EYWO Electric Dryer Logo
83 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
