Question about Behringer EUROPOWER EP2500 Amplifier
Power problem I have a Behringer Europower PMP 2000 Powered Mixer. It is about 6 months old and has been used once. A few weekends ago, I attempted to set it up again for Band practice, however when I attatched the chord and tried to power it on, nothing happened. I thought that maybe for some reason the chord had gone bad so I got another chord. Still no power. I took it back to guitar center where I got and they said that since I did not buy insurance on it there was nothing they could do and I would need to contact you all. Any idea why it won't power on?
  • 2,322 Answers
If you bought it brand new and is only 6 months old, I would suggest to contact the manufacturers to get repaired under warranty since most electronics devices carry one year warranty.
Good Luck.
Posted on Oct 03, 2008
Hi! I need a SM of my europower pmp 2000
This site for the PMH2000 should be near identicla to your unit:
http://elektrotanya.com/behringer_pmh2000.pdf/download.html
Scroll down to "get manual" and click to download schematic. IGNORE other download links.
The HCA2400 amp module in this has a chronic failure and is hard to work on.
Aug 28, 2011 | Behringer Pmp2000 Europower 800w 10ch...
One side of my europower pmp 5000 is out, the other is fine.....what up?
What is up is one of the two power amps is blown... I know this problem... It is USUALLY the rearmost channel which goes to the left Speakon faacing the back. Weak insulation between layers of the multilayer circuit board arcs and fries three transistors and a diode and sometimes a few more components. It takes a lot of skill to restore the module and is beyond most repair shops. A whole new module costs about $155 from Full Compass. The amp is an HCA2400 module, but you MAY need the Behringer part number to order it from Full Compass. Also please read my tip on Fixya for PMP mixers regarding the hazard when using 1/4 inch plugs from the Speakon connectors... the Channel A sleeve is the "hot", not the tip and if you ground the sleeve, goodbye channel A...
Aug 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
My mixer stopped working out of the blue no power want turn on anything ??????????????
Power supply probably failed. This is not a DIY for the inexperienced.
This will be close to your schematic: http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Jul 19, 2011 | Behringer Europower Pmp1000 Powered Mixer...
I need the diagram of behringer europower pmh1000
Here:
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Final amplifier shuttoff after a few seconds
Guessing this happens each time you switch on so it's not a power problem.
Amps have built in mechanisms to shut themselves off to protect from overheating. First thing to do is check the vents are clean and the fan is working properly.
Jun 23, 2011 | Behringer Europower Pmp1000 Powered Mixer...
No amp output.amplifier damage
You will have to have it repaired. Also read my tip regarduing the PMP mixer/amps that if you use 1/4 inch cable plugs to speakers, the SLEEVE of channel A is hot, not the tip. It the sleeve shportss to somehing that is ground, goodbye Channel A or more. This is not in the book.
Feb 19, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Behringer EUROPOWER EP2500 Amplifier Logo
218 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
