Using the HP solutions icon I am automatically connected to my officejet 6100. How do I get the hp scnjet 4050 scanner tocome up
  • jason May 11, 2010
    I tried to help but you never came back and let me know if that worked ( what I explained) on the other post( same as this one)why?
    President:
  • 2,712 Answers
Instead of using the HP solutions icon, go to All programs, and find your scanner entry and create a shortcut on your desktop to the scanner. Now, whenever you want to use the scanner, simply click on the desktop shortcut. This would be the simplest solution..
Posted on Oct 03, 2008
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 4315V scanner will not install with windows vista
Try to scan from paint.....
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Mar 14, 2010 | HP Officejet 4315v All-In-One InkJet...
HP Solution Center does not recognize the scanner anymore... We are operating on a Windows 7 system... the drivers had to be downloaded from the internet because the cd that came with the printer was for...
I had the same problem and solved it. I was using HP Solution Centre to run my HP Scanjet 5590 on Windows 7 Pro 64 bit without problems. Then I ran the scanner using Windows Fax and Scan, but didn't like it, so went back to HP Solution Centre - whereupon the scanner was not recognised.
After hours of reinstalling software etc etc, without success, I suddenly noticed four device icons on the left hand side of HP Solution Centre. These were labelled (when hovered over with the mouse) hp scanjet 5590, hp scanjet 5590 #2, hp scanjet 5590 #3, hp scanjet 5590 #4. Only the top icon was active, but when I clicked on any of the four it moved to the top.
Clicking on hp scanjet 5590 #2 gave me a working installation once more - problem solved. No doubt the multiple icons arose from my desperate attempts to try different USB ports.
Feb 02, 2010 | HP Officejet 6500 Wireless All-in-One...
Need instructions on how to dismantle a HP OfficeJet 6100 Printer to be able top remove the USB interface board. PLEASE Only valid real solutions NO SPAM. SPAMMERS WILL BE REPORTED
open the scanner cover then look for the screw on the four corners of the unit i think only four screw you can dismantle it. You have to use T10 screw. if you remove the screw,lift up the scanner gently to avoid destroying the flex cable of the scanner that is connected to the logic board.Good luck..
Sep 10, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp F4180 printer problem
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr6
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
How can I scan to a PDF file? I am using HP Officejet 5610 printer
To scan a document to PDF using HP Officejet 5610, try the following,
1.) Click the "Scan paper" icon to select HP Officejet 5610, and then scan documents from the scanner
2.) Click the "Build to One PDF" icon to create a PDF document contains all of the scanned documents.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanner won't work with windows vista
Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan .
    NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Jul 01, 2009 | HP Officejet 5610 All-In-One InkJet...
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP Officejet all-in-one 5610 does not send a print job to the queue. Any solution?
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab50
I tried to install hp officejet 6100 series cd for my computer window Vista but it won't work. What shall I do?
Hi debprince45, there is no need for you to buy the CD. You can download it for free from HP. Click on the link below;
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=238398
Make sure your HP 6100 is connected to the computer & power for the printer is connected. Power on the printer. Click on the link;
Automatically check to see if you have the latest software and drivers
Follow the on screen instructions. You'll need to allow HP to check your system. HP will scan your system & download & install the most up to date software for your HP printer automatically.
Good luck debprince45!
Run into trouble, just post here.
Thank you for using fixya.
Merry xMiss!
Mike
Dec 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
54 people viewed this question
jasbo
jasbo
