Question about Homedics Sound Spa Premier SS-5000 Clock Radio
Homedics radio clock light on wall went blank
I removed cord and put it back now numbers upside down, how do i turn numbers back upright?
If this is the projection tube, you can rotate the tube to upright position.
Posted on Oct 07, 2008
Do not have the manual for model ss-5050
Search Results
    HoMedics SS-5010 Clock Radio User Manual - Portable ...
    portablemedia.manualsonline.com > ... > HoMedics Clock Radio
    de obra por un plazo de un a?o a partir de la fecha de compra original, con las siguientes excepciones. HoMedics garantiza que sus productos no tendr?n ...
    Free HoMedics Clock Radio User Manuals ' ManualsOnline ...
Dec 21, 2015 | Audio Players & Recorders
Need the specs for the Homedics ss-5010 power adaptor
Product Attributes
Product attributeProduct Line: SoundSpa
Product attributeProduct Model: SS-5010
Product Summary
Manufacturer: Homedics
Mfg Part#: SS-5010
Buy.com Sku: 211467114
UPC: 031262038029
UPC 14: 00031262038029
Package Weight: 1.9 lbs
Buy.com Sales Rank: 64081
Advertisement middle
Features
Product Type Desktop Clock Radio
Manufacturer Part Number SS-5010
Manufacturer Website Address www.homedics.com
Manufacturer HoMedics EMEA
Product Model SS-5010
Product Name SoundSpa Premier SS-5010 Clock Radio
Product Line SoundSpa
Brand Name HoMedics
Frequency Band/Bandwidth AM/ FM
Tech Specs
Brand Name HoMedics
Frequency Band/Bandwidth AM/FM
Feb 13, 2011 | Audio Players & Recorders
How do I get the battery to work? Is there a trick? I just put in a brand new battery and it won't run. Plug it into the wall, and it's fine. Help
in the manual it says all the batt does is back up the settings and back up alarm but displays will not work. so there is nothing wrong with your unit.
Jan 13, 2011 | Homedics SS-4000 Clock Radio
I just bought Homedics SS-4500 Sound Spa Classic and there was no instruction manual in it. Is there one I can download? I don't know how to change the time that is preset or set the alarm? Thank you.
http://media.homedics.com/IBs/SS-4500_IB.pdf
Also note if projection does not work correctly, Ken posted an elegant solution: holding down hour and minute unplug and plug back in (still holding down hour and minute). Made mine work!
Dec 23, 2008 | Homedics Sound Spa Classic Clock Radio
Need new AC Cord for the SS-6000
I've seen this available on Amazon -- Try this direct link (http://amzn.com/B00ACNGMO8or) go to Amazon and search for the product ID: B00ACNGMO8
Hope this is helpful.
Nov 26, 2008 | Homedics Sound Spa Platinum SS-6000 Clock...
Cant get outside time to work???
I have the same problem with mine. The outside temp displays OK for a while, then it displays two dashs. I unplug the main unit from the wall until the outside temp comes back. I then plug it back in and it works OK. I found that if the remote sensor is located more than 40 ft from the main unit and there are a couple of walls between the two, the outside temp fails more often. I have noticed that putting my wireless phone in it's charging craddle can cause the radio or nature sounds to turn on. I moved the main unit further away from the phone and that cured the problem. Sometimes it will do this if the humidity is low and I build up a static charge and then touch the unit.
Jan 04, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Projection display
I had the some problem a few days ago when we had a power outage during the night. Try unplugging it, leave it unplugged for about 10-20 seconds, and replug it back in. Reset your time on the clock and it should work then.
Nov 08, 2007 | Homedics Sound Spa Premier SS-5000 Clock...
Projection display
To fix the projection display that is stuck with four 8's, hold down the hour and miute button at the same time. Keep the buttons pressed down while unplugging the power source then pluging it back it. I did this and the screen works like it did when I first got it.
Ken
Jan 11, 2007 | Homedics SS-4000 Clock Radio
Projection clock no longer working
just solved my problem that was like yours. turn the clock off at the power for ten minutes and when you turn it back on it should work. mine did!
Nov 17, 2006 | Homedics Sound Spa Classic Clock Radio
Homedics Sound Spa  Premier SS-5000 Clock Radio Logo
301 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
