Question about Dell Wireless Keyboard Optical Mouse w0147
Dell bluetooth keyboard stopped working
The bluetooth light on the keybaord is purple and it does not work,. i changed batteries and still no luck.
  • Anonymous Nov 20, 2008
    Dell BT KB and Mouse worked fine from day 1. Soon as I joined the WS to a domain the KB won't re-connected after comp restart. Mouse works fine anytime. Login as admin w/ Wired KB and setup BT KB then it will work fine until next restart.
3 Suggested Answers
prince kambo
  • 39 Answers
SOURCE: purple light and keyboard wont work
reeinstall the drivers
Posted on Sep 02, 2009
  • 4090 Answers
SOURCE: dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 17, 2009
rajeshpait
  • 542 Answers
SOURCE: Dell Wireless Bluetooth mouse has stopped working
Try updating the driver if drivers are curropted, also check to reset button which is on usb dongle to synchronize, which may solve your problem.
Posted on Dec 04, 2009
I CHANGED THE BATTERIES IN MY DELL MOUSE (SUBTEL 36359) AND NOW IT WON'T WORK NOR IS THE LIGHT ON THE KEYBOARD TO INDICATE THE MOUSE IS WORKING. WHAT COULD BE WRONG?
Did you push the buttons on both keyboard and mouse to sync. Also push button on receiver and see if light comes on. If bluetooth check if connected.
Oct 20, 2014 | Computers & Internet
I have Dell XPS M2010. Windows Vista 32 bit. 350 bluetooth module The mouse connects and works well. The keybboard won't pair. I put it into discoverable mode and the three lights next to the power...
The solution is to formn a class action suit against DELL for this overpriced piece of junk. I went through 3 of them and they all failed.
DELL left these dogs out there in the market until the warrenties expired on all the M2010 machines and now they will charge you for their failure to build a solid product.
The Bluetooth Access Icon is nowhere to found in the control panel, so the manual is wrong as well.
DELL is acting irresponsble and needs to be punished. Let's form a Class Action Suit today.
Apr 14, 2011 | Dell XPS M2010 Wireless Bluetooth Keyboard
Dell Wireless Bluetooth mouse has stopped working - changed batteries - bluetooth light flashing - help
Dec 04, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Nov 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless keyboard and mouse not working
Hello
Some wireless keyboards and mices have a button that enables the locating signal of the device, this button when pressed locates the receiver and initiate a pairing with the host. Look below you keyboard and mouse, and if your keyboard is a Bluetooth device, then check in your computer if the bluetooth is enabled and drivers are installed.
good luck
May 23, 2009 | Dell 0Y3740 Keyboard
Dell Inspiron 1525 keyboard stop working - how can i fix it?
Try in safe mode:
Switch on the laptop and start tapping 'F8' key multiple times (especially when you get the dell logo.Locate safe mode and hit enter (by using the down/up error key).Open a notepad and check all the keybaord keys one by one and confirm if it works.
Test keyboard:
Switch off the laptop (if it is already switched on). Press "Fn" and power key together, this will launch a test (psa), wait for a message "where the color bars displayed",press 'Y' to continue the test. follow onscreen instructions till you rach a window with four options,(express test,symptop test,custom tes,,,,,), click on custom test and select keyboard, click on run test.....and confirm if keybaord works while running the test.
Regards,
Musheer.
Dec 07, 2008 | Dell F3534 Touchpad
Dell Wireless Keyboard Optical Mouse w0147 Logo
195 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
