Question about NEC VT570 Multimedia Projector
NEC VT695 (not a vt570) bad lamp blowing ballast board?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I am working on 2 NEC VT695's (we have hundreds of them). However, one of them is not lighting lamps, when I put a new or known good one in it, it does not light or will try to light then go out immediately after the initial HV ignt charge. And when I take the lamp back out and put it another projector that projector will no longer work either. Can a lamp cause the ballast board to go bad on another projector? (All pins are infinite on ohms,and not shorted which I would expect with a good uhp/vhp lamp or a bad one). This is not a fluke; I have gone through 4 lamps and now 2 projectors. Do you have any Idea's?
PS- the original projector that is causing the problem seems to have a bad n-ch MOSFET on the ballast board (not shorted). But I am still confused on how one projector can burn a lamp and that lamp burn out a ballast board in another projector? Any input would be helpful.
  • 74 Answers
We have the same model here at our school too. I know of two that have done exactly what you said. I am trying to figure out if this is NEC fault. Bulbs are expensive and if the projector and NEC is a fault; we will definitely be moving on to a different brand.
Posted on Dec 08, 2011
I have a nec vt570 projector and it has gone into bypass mode because I let the lamp go to long. I've replaced the lamp but can't reset the hour meter.Is there any way to reset without the remote
Switch on the projector in standby mode.
press the HOLD button on the remote for 10 secs.
the projector will come out of protection and you are good to go!
ensure that u replace a new lamp!
This can be done only with the NEC remote!
Jun 04, 2015 | NEC Office Equipment & Supplies
Why does status light flash red on VT695 proxima?
Usually it's a warning that the lamp is either close to it's end of life or it has expired.
Sep 08, 2014 | NEC VT695 LCD Projector
Turn control panel locked
1,turn on the projector
2,pressing and holding the exit button on the projector for 10 seconds
3,ok
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | NEC VT695 LCD Projector
Np2250 lamp will not shine
The wires that go from the bulb socket to the circuit board is the ballast. This board controls the lamp operation. It is most likely the source of your problem.
Jan 13, 2014 | NEC Brand NEC Replacement Lamp For NP1150...
Nec vt695
Did you unplug it before you replaced the bulb?did you touch the bulb?are you sure the bulb works?have you reset the lamp hour meter?did you replace all doors, screws and original parts?is the bulb securely in place?
Here is your manual http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf
Mar 29, 2013 | NEC VT695 LCD Projector
I have a LT60LPLK lamp and I wanted to know how I could test it, outside of the projector, to see if it works.
Don't even think about because lamp is supplied with high voltage and You can get snapped realy badly as well You can blow ballast if you short something
Bad idea!!!
Aug 20, 2011 | NEC LT60LPK Projector Lamp for LT220,...
I want to connect my iPad 2 to the NEC video projector VT695. do I need a VGA or an AV adaptor?
you need this ----------- Apple MC552ZM/A Video Cable Adapter HD-15 Video - Male Proprietary
Jun 17, 2011 | NEC VT695 LCD Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
Samsung hln4365w no powerup flashing lamp & temp. can i repair myself & where do i get parts?????
There should be a lamp code sticker on the left side of the tv.bp96-00224c or bp96-oo224a are the part #'s for the 2 lamps used on this set,but you need the right one or it will blow prematurely because of 2 different ballasts used.
Aug 22, 2009 | Televison & Video
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
NEC VT570 Multimedia Projector Logo
525 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
