Front panel audio connection to asus pk5 se mobo
Hi, I have an x blade gaming case and i am trying to wire up the front panel hd audio connection to my asus pk5 se mobo. the trouble im having is the names do not match up and i cant find the instructions manual for the case, any help would be really appriciated, many thanks Tracy
  • tracybow Oct 23, 2008
    hi, thanks for trying to help but i still have not solved this problem, i have the motherboard manual the problem is the names for the wires are totally diffrent to the names on the motherboard thats why i cant work out what goes where, I dont know if i explained right the first time, its the mic and headphone wires i need to connect so i can plug them in from the front of the comp, if anyone could shed any light on this it would be most appriciated
    thanks Tracy
    Problem Solver:
  • 10 Answers
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Posted on Oct 04, 2008
  • rapitec Oct 24, 2008
    Hi Tracybow, in the diagram of your Motherboard you should see something like "Front audio connectors" or "Front audio speakers"...usually it has a total of 5 pins. You will see also some cables inside your PC case which are unpluged. Please let us know the names of these connectors of you PC Case. They should say something like "Left Speaker " (2 connectors), "Right Speaker " (2 connectors), Mic (usually 1 connector),
    Best regards
    Eduardo
ASUS P5KPL AM/PS front audio not working
Is the front panel audio connected to the motherboard? With any problem involving Wigglies(electirics) you should check your connections first, then fuses. In your case just the connections.
Mar 08, 2012 | ASUS P5KPL-AM/PS Motherboard
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with IntelĀ® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
How to activate front panel audio for P5KPL-AM SE?
you connect your front panel cables to to the motherboards front panel connectors to activate the front panel audio.
for more reference you can download your motherboard manual in Asus website below
http://support.asus.com/download/download.aspx
Feb 02, 2011 | ASUS P5KPL-AM SE Motherboard
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Dell Asus M2N61-AX MB front panel connector Nix ATX Gaming case
I assume you mean the HDD,reset,on switch etc where they plug onto the mobo.
Most mobos are labelled on the board but you will need good eyesight to read. They are labelled HDD, RESET, SPEAKER etc.
If not simply look up mobo manual from vendors site. You will need the DELL serial / part number from the old unit though.
Apr 29, 2010 | ASUS Computers & Internet
Front ear and Mic plugs not working
I assume they checked to see that the front ports were hooked to the header on the mobo? In some cases you have 2 plugs on the header, one marked AC 97 and the other marked HD Audio. Make sure the correct one is selected in the bios. Also, on some Asus mobo you can disable the front panel audio in the bios. Check that also.
Sep 06, 2009 | ASUS Intel 5000P Chipset...
I'm trying to hook up the front panel audio on my new case.
Usually such info are given in the user's manual. If it is not there, then try downloading the maintenance manual. (ehteshamhusain@gmail.com)
Jul 17, 2009 | Computers & Internet
Asus chassis wiring confusion for front mic input [colour code?]
the wires comming from the front of the case. at the end of the wire on the black insulator should have a stamp on it telling what the wire is.
Mar 22, 2009 | Computers & Internet
Front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
technician.
Aug 09, 2008 | ASUS Vento 3600 Dream Extreme Gaming ATX...
Audio deosn't work on mobo
Hi Chris, the problem can be one of two issues. If the sound jack located at the back of the PC did function at the same time as the front case sound jack. Than the problem is the jack it's self is bad. (Back of PC). Someone had to hook up the front mic & sound jack to the motherboard. So disconnecting the front sound & mic may give you rear sound & mic.
Turn to page 2-29 in you're user manual for the Asus M2N-SLI. The pic shown is the default setting for the front case audio & mic. (What you do see are the two jumpers connected). So disconnect any connector & place a jumper over pins 9 & 10, (last two pins at the right of the two rows of pins). Place another jumper over pins 5 & 6.
Pin 1 is the first pin on the left bottom row (MIC2). Pin 2 is the first pin, left edge top row (AGND). Pin 8 is not installed but you still count its spot as if there was a pin. (This is how the board was setup from factory). Once you fix this you should regain sound & mic function at the rear of the PC. To fine tune the audio run the Asus sound effect manager. If you installed this software, (Recommended). If it’s not by you're clock than it’s in control panel.
Link to all for M2N-E SLI
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Good Luck!
m
Jun 07, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computers & Internet Logo
861 people viewed this question
David Payne
David Payne
