Question about Lexmark C510 Laser Printer
Lexmark c510 vertical banding
My lexmark c510 displays vertical banding. (lines that are vague but definitely not on scans. I believe this is result of moving the printer. It was carefully packed and toner cartridges were removed but not the photo developer. Still I could have damaged the toner cartridges also because I didn't properly pack them. Though my guess is that banding is caused by damaged photo developer. What do you think?
  • Anonymous Nov 03, 2008
    I have two vertical lines printing in all four colors like the cartridges smudged. Any help in how to clean the printheads?
  • 193 Answers
Try the transfer belt...during printing, create a paper jam.
look at the transfer belt or drum...if you see lines..well, you know!
follow it through..think out side the printer.
Posted on Oct 05, 2008
Lcd replacement for C510
According to the User Manual on page 82:
"If the messages do not appear, turn the printer off and
contact the Lexmark Customer Support Center at 1-859-
232-3000 or http://support.lexmark.com. "
Attaching User Manual.
http://images.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Feb 18, 2014 | Lexmark C Office Equipment & Supplies
I have put up with a banding problem on my Lexmark c510 for over a year, along with a loud grinding noise when printing . The problem still occurs when print a separate page of each C Y M K colour. How...
Lexmark has nozzle check feature, which prints test
page so you can see if nozzles are working. It's under printer
properties/maintenance or similar.But depends which type of ink did you use for refilling. If you used so-called universal ink for all printers, then you're stuck. I tried such
ink on my Z33 and got same result. I ended with new Canon i550.If you did use such low-cost ink, i suggest you totally disassemblecartridge, clean it thoroughly, dry it and get new ink specially designed for Z65. When i got this result, i took out sponge, clean it, clean cart
itself until clean water was coming from nozzles, dried it out and refill. let me know the result.
Jan 07, 2011 | Lexmark C510 Laser Printer
I am getting vertical lines on my pages. It is as if it is not printing there. Any suggestions? Thank You!
Please clean the printhead laser lens.
Pull the toners out and open the smalll door below and wipe the lens with a clean lint free piece of cloth.
This should take care of the vertical line issue.
Regards.
Jan 15, 2010 | Lexmark C510 Laser Printer
I get a line through my scan with my hp photosmart C6180, What can I do?
If it is a vertical line, you could review the HP support documentation for your Photosmart C6180 here:
HP Vertical Lines Bands Streaks
For horizontal lines, try using the HP "toolbox" to clean the print heads. You may need to repeat this process until you achieve a satisfactory result.
Dec 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
ON Lexmark C510: On left edge of paper, I have small lines
your copier scaner mirror is dust over clean it then solve it
Jun 25, 2009 | Lexmark C510 Laser Printer
Lexmark c510
Hi Spencer,
I found Lexmark's web and they have a ton of info. I narrowed it down to the user manual and on page 84 and 85 it has the paper quality troubleshooting:
http://publications.lexmark.com/publications/pdfs/c510/eng/userref.pdf
best wishes.
Jul 05, 2017 | Lexmark C510 Laser Printer
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
Lexmark C510
try to clean the toner from tissue paper or if you want good quality you replace the toner or copen the cover of printer toner and clean is there any ink powder is there. bye
Sep 21, 2007 | Lexmark C510 Laser Printer
Lexmark C510 Laser Printer Logo
320 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
