Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Does not always spin
Spin cycle does not always work. If I move the tub by hand and restrart the cycle it will spin. The high speed spin seems to be slower than other washers and it takes a long time to build up speed.
    Novelist:
    Champion:
  • 261 Answers
How old and is it on all loads? How fast to stop the machine when you lift the lid? Can you stop the tub while spinning, careful on this one?
Posted on Oct 06, 2008
Shakes like crazy spin
Your maytag washer tub and basket assembly sits on a base counter balanced by 6 springs. Is is possible to move the tub around by hand. The best test is to start a spin with the unit empty of cloths, allow the tub to reach speed for a few seconds, lift the lid and check the tub position after it stops, if the tub is off center with the lid opening, re center the tub and run spin again. If your tub returns to an off center stopped position you most likely will need the base kit replaced. The base kit replaces the entire bottom of the unit along with new springs, and snubber, if so packaged per your application. Maytag experienced a defective stamping dye when these bases were stamped, thus they were stamped crooked. This test is performed with the machine it's self relatively level on the floor. If the tub assy leans and favors any one direction while you are trying to center it with the lid open, you may have a rusted or broken counter spring in side the unit. Pleazer Appliance...
Apr 11, 2014 | Maytag Washing Machines
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
Door is locking but machine will not execute spin cycle
My washer is draining the tub but it's not spinning .Would this be minor or should i buy a new one.
Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer vibrates terribly loud on high speed spin cycle
Either bad motor, motor bearing, tub bearing or idler pulley (also broken motor mount). Unplug unit. Spin tub by hand. Try and feel if spins freely. If direct drive unit (no belts). Most likely tub bearing or motor. Remove rear panel. Inspect for damage (broken mounting parts). Turn tub by hand. Look for malfunction.
Jul 10, 2009 | LG WM0642H
Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Dec 18, 2007 | Frigidaire GLTR1670A Front Load Washer
Noisy clothes washer
I am thinking there may be an object caught between the inner and outer tubs...perhaps something came out of a pants pocket and was "flung" overboard into the outer tub. If you remove the top, and push the inner tub (moving tub) to one side, look with a flashlight for a foreign object. the noise will be fine until high speed kicks in and begins to disturb the sleeping object into a frenzy.
Jul 25, 2007 | GE WHRE5260E Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal De
