Question about Amana Washing Machines
Water leaking between drum and top of gear box.....Washer is an Amanda NAV5800aww
    Genius:
  • 1,028 Answers
Center seal leaking ..repair not for faint of heart if you hire it done be sure they change upper bearing ..water is leaking onto bearing and failure can occur in less than 2 weeks after seal replacement
Posted on Oct 05, 2008
During wash cycle on Amanda front load washer, water leaks from the top down the side
Sounds like the door seal is shot. Try searching "amana washing machine door seal". You get YouTube hits on how to and suggested parts suppliers. Alternatively get a local technician to look at it.
Jun 16, 2015 | Amana Washing Machines
Washer leaks on floor from drum top while centrifugating
Good Morning Andres,
I see that you are having trouble with your Frigidaire laundry center, model# FEX831F, and the washer leaking water from the drum top onto the floor. It could possibly be that your washer door is either not closed all the way or is not sealing properly. I suggest checking to make sure that the door is closed all the way. If it is, I would check the seal, and see if there anything that might be damaged and allowing water to leak from the drum top. If you are unable to find anything that might be allowing the water to leak out, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and see why you are having water leak from the drum top. Hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire FEX831F Top Load Stacked Washer...
Nav5800aww
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Sep 13, 2013 | Amana NAV5800A Top Load Washer
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Internal leak on a kenmore top load washer
Yes, very likely is a bad water inlet valve allowing water to leak past it into the drum. Really not a difficult repair with a little help.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Sep 13, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Thick Gear-like oil leaking from the bottom somewhere
looks like your washer is developing a leak from the seals in the drum thus allowing some water to seep into the bearings get it checked before the bearings run out completely
Jul 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
Washing Machines Logo
210 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
