Question about Xerox Phaser 4500 Printer
Open heat error
I am getting an Open Heat error on my xerox phaser 3200 mp printer / fax machine. I have to keep powering it off then back on and it goes away for a little while then comes back.
    President:
  • 2,072 Answers
One of 2 things is happening, Either the Heating element is going bad, or more likely the thermistor that monitors the temperature of the fuser is intermittent. You will most likely need to replace the fuser to resolve the issue. That machine has a one year on site warranty. If its less than a year old Xerox will fix it for you free of charge.
Posted on Oct 04, 2008
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Heat tempreture in Phaser 3200 MFP Fusing part
This option does not need to be changed unless you are getting a overheat error. If you lower the heat on the fuser this can result in image transfer on the paper leaving blotches and ruining the fuser.
Jan 22, 2014 | Xerox Phaser Office Equipment & Supplies
Open heat error
Open heat error is caused by a bad fuser. Replace the fuser assembly.
Jan 20, 2014 | Xerox Phaser 3200MFP/N Laser Printer
Hallo, i have xerox phaser 3200 i want ask something why when i turn on the printer warming up progress can't finish (always warming up)
Srri but this is a fuser failure. The lamp has probably blown so it cannot generate any heat. best buy a new fuser unit. A lot of the machine has to come apart to fit it. You would be better taking it a shop for them to repair it.
srri
May 23, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Says scanner locked phaser 3200
Under the scanner, entering your hand over the exit tray you can find a green slide plastic that you must locate in the open position, once made this, you must power off and on your printer.
Feb 22, 2011 | Xerox Phaser 3200MFPB Multifunction...
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Xerox Phaser 6110MFP reports FM_IO.c 172 ROOT during startup
Also make sure you have the machine plugged directly into the wall outlet...some surge protectors or multi-outlet strips won't allow sufficient power to properly boot up and run the machine !
Dec 10, 2008 | Xerox Phaser 6110 Laser Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
920 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
