Question about Acer AL1511 15" LCD Monitor
Horizontal display size adjustment
I have 3 acer AL1511s with the same problem. If the monitor auto configs the display reduces in size leaving a black area on the right side of the screen. I can move the display over to the middle of the screen but there is no way to increase the size of the display to fill the screen.
    Scholar:
  • 155 Answers
Make sure the video resolution is set to 1024x768.
Right click on a blank area on your desktop. click properties>settings.
Posted on Oct 04, 2008
  • Rachelle Aviles
    Rachelle Aviles Oct 04, 2008
    If the problem got fixed, I'd appreciate if you can rate me.
Acer 1916w Auto config. problem, every 5-10seconds, re-adjusts, makes it almost impossible to watch. any ideas for the DIY guy? thanks!
Obviously you've checked the connections are secure both sides? - thats the usual culprit.
Otherwise take it out and leave it off (power unplugged also) for minimum 5 minutes and that will clear any memory and capacitors, then try again.
Oct 29, 2010 | Acer AL1916W 19" LCD Monitor
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
Monitor's display is shifted up and right so that there is just black space to the left and all along the bottom whereby cutting off the display. cannot see bottom menu bar.
One of the buttons on the front of you monitor (bottom right hand corner of the bezel) is a menu button. Press that then using the the arrows up and down buttons go the the horizontal and vertical positioning option. Once chosen move the display as desired.
You could also press the Auto (config) button, that may do the same for you.
May 17, 2010 | Acer AL1912 19" LCD Monitor
Display wont expand to the left
What brand and model of monitor is it? Usually there is an auto config button that makes everything right. It is usually labeled Auto. If that doesn't fix it, press the menu button and see if you can increase the horizontal size and move it. If that doesn't work, take the monitor apart and reconnect the video cable that goes into the panel.
Jun 12, 2009 | Computers & Internet
Can't change W to H ratio
use another monitor crt not LCD. adjust first the resolution. then connect again to your acer LCD. or you can auto config your acer from menu.
May 29, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
Monitor "offset"
try adjusting your refresh rate
Dec 13, 2007 | Acer AL1912 19" LCD Monitor
Acer AL1511 15" LCD Monitor Logo
516 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
