Lost all av channels on my techwood 3211 lcd tv.
I can't get the av channels to work on my tv. tried everything in the manual,but when i press rthe av button i lose use of the remote and the buttons on the side of the tv. i have to turn it right off to get it to work again but it will only let me watch tv. no play station dvdv vcr nothing will work on it just the normal telly. i've tried everything i can to fix it but have no idea what is wrong, could someone please help? thank you!
  • zak8287 Oct 24, 2008
    get me 21"tv system codes list
  • 3 Answers
System ic codes
Posted on Oct 24, 2008
    21"tv system codes
I have a techwood 32 inch tv,model no32 a01cb,is it possible to use this with out the remote as i have lost ithe remote,or can i turn it on manually
A universal remote might work for you. Usually you can get the TV out of standby by pressing the channel select button.
Jun 25, 2016 | Office Equipment & Supplies
Lost the remote. How do I switch TV/AV to play video?
If there is a mode button, otherwise if there are not other buttons on the set itself, try tuning channels with autoprogram or channel add/edit and see if there is an INPUT or AV channel.
Otherwise you can get universal or origonal remote online.
Oct 27, 2009 | Orion STV2763 27" TV
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
I lost the original remote to my 27'' television
very sorry for that but you can be changing channel manually on the tv channel buttons, if you sweep on all channels you can go to AV from RF channels, that is before you buy a remote.
try to buy your remote from
www.ebay.com
Apr 28, 2009 | Televison & Video
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Lost remote
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one...The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
A disappointing TV to say the least.
Feb 11, 2009 | Emerson SpongeBob SquarePants TV
Lost remote
what kind of universal remote are you trying? They're all different
Sep 12, 2007 | Polaroid 3211TLXB 32 in. LCD Television
Televison & Video Logo
327 people viewed this question
Top Televison & Video Experts
Electro Med Services...
