Question about HP PSC 2210 All-In-One InkJet Printer
Connecting to printer on wireless network with built in wireless adapter
This sounds complicated, so let me explain. I have DSL with a wireless feature activated. The printer is connected to the main computer which is also connected to the DSL router. My laptop connects to the DSL with a built in wireless adapter. It will not, however, recognize the printer.
Using another laptop, with a wireless G adapter (Lynksys), it connects to both the DSL and printer.
Can anyone tell me how to connect the newer laptop to the network and printer?
  • 1 more comment
  • amazinpack Nov 16, 2008
    I have the main desktop computer with a printer connected to it with a router. But when ever I try to connect my laptop to the printer it doesn't reconize it.
  • mary dee Jul 05, 2013
    me to
  • Anonymous Apr 01, 2014
    My printer is connect to my router. It works on one of our home computers, but not the other. It is not connect via USB to either one of them.
I want to connect my laptop to the network printer. Please help!
Edgard
Posted on Feb 09, 2009
    Genius:
  • 1,124 Answers
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
Posted on Oct 03, 2008
How can i connect in dsl modem with laptop?
If your laptop has no built in wifi, a USB receiver can access nearby (wireless capable) routers or router/modems. Otherwise a CAT5 cable can hardwire your computer or laptop to a DSL modem. CAT5 is a little wider than telephone connectors. Then install drivers (and make sure the modem is compatible with your providers requirements, they are not all the same.)
Nov 05, 2013 | 2wire (1000-000005-002) 802.11g/b Wireless...
Do I need any special equipment other than the ethernet cable connection for my linksys broadband wireless-g router
That's all you need to get your wireless internet up and running. However, in order to connect computers to the wireless network, they must be wireless capable, for example, most laptops have built in wifi, however desktops will need a wireless adapter to take advantage of your wireless router.
Mar 03, 2011 | Linksys Wireless-G Broadband Router
How do I hook my wireless usb netopia chip in order to sign on the internet
You ned to contact an Internet Service Provider to determine if your USB wireless adapter is compatible with their service.
Read this info for an idea on how to connect to the Internet :-
There several ways to connect to the Internet.
1. You can use a cable or DSL modem and connect this modem to the laptop with a LAN cable.
2. You can use a wireless router with a cable or DSL modem and connect to the wireless router using a wireless card (a PCMCIA wireless card or the laptop may have a built-in wireless card). This wireless card can also be used in WiFi locations such as the airport, McDonalds and Starbucks etc.
3. You can use an USB G3 wireless adapter. This type of device uses the G3 mobile network and may not give you Internet coverage in some locations.
All these require an Internet Service Provider and the costs vary widely depending upon the various plans they offer. Check the ISP in your area and compare the plans and cost of their plans and pick the one that best suits your needs.
Sep 11, 2009 | Computers & Internet
Laptops not connecting to the internet when the hp c4599 is on
Perhaps the printer is conflicting with the laptop by taking its "address" on the network...Do you know how to give your printer a diifferent IP address? Or your laptop? Its a bit complicated to explain but if you can make sure the laptops and the printer are all set to use "DHCP" then they should all each get an adress on your home network and work together.
In Windows Vista, click Start, Control Panel, Network & Internet, View Network Status and Tasks. Then view the status of your Wireless Network Connection and click details, if it says "DHCP Enabled" in there then your laptops are not the problem and should be sharing addresses.
You should be able to see in the printers control panel or by printing a self test page how its setup on the network, maybe it needs to be reconfigured while the laptops are turned on as well.
May 17, 2009 | Office Equipment & Supplies
Laptop to access printer wireless
First, can your labtop see your other computer on the network. If it cannot see the other computer you will not be able to print from your laptop. I had a lot of troublel with this until I purchased a program called Network Magic from www.purenetworks.com. It was easy to install and made setting up my network and shared printers easy. It cost $30.00 and is worth every penny.
Jan 15, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
Oct 29, 2008 | Computers & Internet
Compaq presario c500..what do i need to buy or purchase to use the internet?
This model has a wireless network adapter built in, so if you are on DSL isp connection you need a wireless DSL modem/router, if cable then a cable router to attach to your cable modem.
Sep 11, 2008 | Compaq Armada 3500 Notebook
Hi, I just bought a Belkin Wireless G Notebook Card and having install trouble.
its called express card.. and your 1501 has built in wireless adapter already.
what u need is a router to hookup to the dsl to transmit th signal to the 1501 antenas built in
Aug 18, 2008 | Belkin (F5D7011) 802.11g/b Wireless...
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
HP PSC 2210 All-In-One InkJet Printer Logo
574 people viewed this question
Seeker5211
Seeker5211
