Question about RCA D52W135D 52 in. TV/DVD Combo
Rca hdtv the picture in a sideway hourglass. There are three images of each object each in a different color. The colors won't come together.
  • trryjoe5629 Nov 07, 2008
    I have the exact same problem.
    Problem Solver:
Sounds like a convergence problem... do you have red, blue, or grean outlines (double image)? If so you will need to change the convergence board or convergence amp (driver board) Not to expensive or difficult. Might have to make some touch ups in the convergence menu after you get done changing the board.
Posted on Jan 02, 2009
  • 962 Answers
Check the Fly Back Transformer. be careful when trying to fix TVs. they retain electric currents even if you have disconnected them.
Posted on Nov 13, 2008
I have a RCA 52inch hdtv that has three color lines red green and blue at the top of the screen together and then they separate. It turns itself on and off. And the images on the screen appears to be three...
Go to Menu then setup ,Do you see Convergence, If not then you have a Blowed Fuse on the Deflection Board FL231. Deflection board will be the bottom lefthand side with FBT flyback transfomer on it and on the right hand side of FBT is 3 Fuses in a roll but they do not look like Fuses they will be small rectrangler looking caps but are Fuses it will be the one in the Middle. .06amps. If you have anymore question let me know . Thank You
Jun 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture has a triple image
Very common and easy fix. Install the RCA repair kit called ' ITC222 and ITC222A convergence option missing repair kit. Its available from and contains the parts and the CD with repair instructions.
Jul 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Converging problem
This is a rear projection TV that uses three color "guns" in a cathode ray tube . They are no longer converging at the screen. The convergence problem is usually a sign of something else gone wrong with the high voltage.
Do NOT attempt to open this set yourself. This type of TV can have LETHAL voltages inside for WEEKS after it is unplugged. The repair and convergence calibration will require a qualified service technician.
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
My Panasonic PT53WX52F has a sideways hourglass picture with the green scroll running in an arc with the same red scroll running straight across. Is this the convergence chip you talk about?
There are two common problems with these sets.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 23, 2009 | Panasonic PT-53WX52 53" Rear Projection...
50 in rca tv
Either color wheel or ballast is faulty.
Oct 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red sideways hourglass
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Jul 20, 2008 | Philips 60PW9363 60" Rear Projection...
Showing picture in three segments
Test through MENU? explan that please. are there different colors that lead you to idea that is convergence.
Jan 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Hourglass effect and fuzzy
You have a convergence problem and I suggest to get a qualified honest tv repairman because this is a highly technical problem in this model. Hope this helps
Dec 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
RCA D52W135D 52 in. TV/DVD Combo Logo
126 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
