My laptop will not connect to internet through wireless router without cable connected to laptop from router
  • Cason Ramos May 11, 2010
    Does your laptop successfully connect to the wireless router wirelessly but cannot get on the internet? Or does the laptop not connect to the wireless router at all?
    Genius:
  • 1,124 Answers
You have to set the connection.
Check first if you get the signal from the router on your laptop
Go to wireless connections
If you get the signal, select the right network (yours) and connect the device.
If you need more help see this http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Posted on Oct 03, 2008
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jun 16, 2012 | Samsung Computers & Internet
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
How do i connect this laptop model to the internet without using dail up
The Laptop must have a wireless option for wireless connection to a wireless router, or an Ethernet cable so you can connect to a normal broadband (DSL) modem / or wireless router.
Aug 24, 2010 | Computers & Internet
How do I connect my netgear router to my desktop internet to use with my laptop. Followed instructions but when cable is disconnect from my laptop I can't connect to the internet
First Connect the Desktop with Netgear Router with the Ethernet cable. Open the Netgear GUI and configure a Wireless Network. Once its configured, switch On the WiFi switch from your Laptop and try to connect your Laptop. Make sure your laptop has an in-built Wifi adapter, if it doesn't then you would need to buy an USB based Wifi Adapter.
Also if you want to use the Internet with your Desktop PC without being connected with the Netgear Router then make sure it has Wireless connection capability.
May 10, 2010 | Computers & Internet
WRT120N how to enable wireless option
Wireless should be enabled by default on the router. Check whether you have switched on wireless on your laptop.
Please rate if helpful.
Thanks
Apr 13, 2010 | Linksys WRT120N Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Rangemax-internet only works when comp directly connected via LAN
it sounds like you have the wireless connection to the WAN disabled. Go through the wireless settings on the router and check to make sure it's not being blocked from the WAN/Internet connection.
Nov 11, 2008 | NetGear RangeMax WPN824 Wireless Router...
Cd won't load on computer
You may configure your router without using the cd.
Using an ethernet cable, connect the router and the laptop so that you can configure it for internet connection.
1. check physical connection. modem to internet port of router. laptop to numbered port of the router.
2. check lights.
3. on your laptop go to the command prompt. (type cmd on the run window)
4. type ipconfig/all on the black screen
5. look for ip address. IP address should be in this range 192.168.0.*
6. open your internet explorer browser then type http://192.168.0.1
7. type admin on the username then password or 1234 on the password box.
8. configure the router for dsl or cable connection. don't forget to save
9. check if you have internet connection. if not, power cycle the modem and router.
10. once you're online, go to wireless tab. set your ssid (any name you want). set your encryption (either wep or wpa) don't forget to save
11. unplug the ethernet cable from the laptop and the router.
12. if the wireless card of the laptop is configured, you may click the wireless connection icon at the system tray (near the clock). enter your ssid and encryption.
13. you should have internet connection.
Nov 02, 2008 | NetGear WGR614 Wireless Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Internet problem
well..if you can see the router, then it's between the router and the internet..can we assume the router is plugged into the internet feed?
May 01, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
