Question about Onkyo TX-DS595 Receiver
DTS Does my reciever have a DTS decoder?
    Brigadier General:
  • 8,546 Answers
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Auto format decode means?
There are so many audo formats like Dolby Digital Decoding, Dolby Digital EX Decoding, Dolby Pro Logic Decoding, Dolby Pro Logic II, Dolby Pro Logic IIX Decoding, dts 96/24 Decoding, dts Decoding, dts NEO:6 Decoding and dts ES Decoding Stereo etc. What ever the AVR get a digital input It will decode the format and convert the same While it in the Auto format mode. If auto format is not selected it will convert the same in to stereo.
Feb 09, 2012 | Audio Players & Recorders
Didn't supporting DTS when playing DTS filims no sound is hearing i would like to make DTS support on my dvd philips any codecs for that or any other way?
Maybe your player,simply does not decode dts streams.
All you need to do is to buy a decent receiver with digital inputs.Connect player to receiver using an optical or coaxial cable[or hdmi 1.3/1.4 cable] and let the receiver do the dts decoding......
Don't forget:sett the audio output in your player to "bitstream".
Jan 19, 2011 | Audio Players & Recorders
Hi i have problems with SOny STR-DE958 and DTS. I use Win7 and optic cable. When i test for DTS my Sony didn`t make any noice. Only work Dolby. I test with normal cables in Multi in all work. And optic...
What's connected to what? And which way are you going? Is a PC part of this scenario (you mention Win7)? Maybe you should start there.
The Sony knows DTS. The PC, who can say?
DTS is a bitstream-audio function and many sources need to be told to send it to their digital outputs because without decoding it will only sound like high volume static noise. The DTS-compatible receiver decodes it to its analog multiple channels. It doesn't suk. Look it up on Wiki.
Feb 10, 2010 | Sony STR-DE598 Receiver
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
DTS has never worked
Go to Manual program and keep the decoder field on Auto Mode.
Oct 01, 2009 | Yamaha HTR-6130 Receiver
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
Jan 24, 2009 | Onkyo TX-SR606 Receiver
It is a preamplifier with sound processing which is sometimes referred to as pre pro... There is a simple solution to lack of DTS, the unit has 5 analog bypas inputs, bypass as they do not go through units Digital Signal Processing circuitry and DD processor.
If you have a DVD/BD player that has five (or more) analog outpusts you plug them in into your preamp and have the player decode DTS to analog signal. If the player has five analog outputs it mostly like has the on-board decoder. Other than this you can use a stand-analog DTS decoder in the same manner but it sounds like a cumbersome and costly alternative. Hope this helps.
Apr 26, 2008 | Sony SDP-EP9ES Receiver
Onkyo TX-DS595 Receiver Logo
146 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
