Question about Nokia 3315 Cellular Phone
Screen Replacement damaged signal strength
I bought my Nokia 3315 in India a few years ago probably in 2004. This year accidentally I dropped my mobile on a highway road while driving and a Heavy Truck fully loaded went over it and damaged its screen. I was however able to receive calls and also turn on the phone after this incident happened hence I went to a local store and had the screen replaced. Since I was in urgency I left the phone with the repair guy and by the time I returned it seemed as though he replaced the receiver though all other components on it bore the original look that I left it with him. Now the issue is that after the screen has been replaced which again broke since there was play, it does not receive the signal it originally used to receive. If I am say more than 10 ft from the tranceiver there is literally minimal signal and if there happens to be a wall between me and the tranceiver within this distance then there is no way I can search for any network even by manual option. Please suggest how can I repair this phone so that it can boost the signal strength and also have the screen replaced since I do not trust repair vendors now.
  • muralimohan Oct 03, 2008
    Hi thehumble1,
    I have reviewed the take apart snaps and feel that the repair guy actually replaced the original part shown in pic 4 since there was a small copper pinned plastic casing under the screen which came loose after the first accident even now when I removed the metal panel above the display to actually remove the broken display itself there was this loosely held copper pinned plastic casing still lying loose. I think I need to get the phone replaced as you said since we cannot have only the panel replaced.
    Thanks,
    Murali
    Novelist:
  • 137 Answers
I'm guessing that the antenna was disconnected or damaged during repair. I've had a few of these phones open and know it is easy to do. If it's been too long, since you got the phone repaired, to go back and complain, you might have to replace the phone. Forgive me but I have no idea what you are talking about when you say: "receiver" and "transceiver" because this is a cell phone and doesn't have a separate receiver or transceiver.
I had this phone and it's easy to take apart, I believe it actually has replaceable covers so it might be true that he replaced the screen and front/back panels. It might also be a problem that it was damaged when A LARGE TRUCK RAN OVER IT.
These phones have an "internal" antenna, which might be a coil of wire, or a small layout of copper traces that create an antenna. If you take the phone apart look for one of those and see if you can plug it back into the main board.
TAKE APART FOR NOKIA 3315/3310
Posted on Oct 03, 2008
  • Daniel Herd
    Daniel Herd Oct 03, 2008
    hey, it's testament to Nokia that it somewhat survived the truck incident. Too bad technicians are more dangerous than fully loaded semis
Hi, i've bought a new canon camera (powershot
You probably need to move the small switch on the memory card to the open position.
Oct 28, 2013 | Canon PowerShot A810 16MP 5X Optical Zoom...
My cq50-211nr laptop was accidentally dropped and has a crack.
Ordering the part and replacing it yourself may be just a tad cheaper, but at a risk, may break new screen or cause problems with more parts, I would take it to HP, then again, an LCD screen replacement costs about the same as a new compuer. It's really up to you.
Good Luck ;)
Apr 06, 2010 | HP Compaq Presario CQ50-211NR Notebook
Nokia 6310i - Low and No signal
It's possible that you could fix it, but not entirely likely. It depends on whether it's just a bent antenna connector or if a circuit board is broken.
Some phones have a small spring-type piece that makes contact with the antenna. If this is merely bent, and not making a great connection, you might be able to coax it back into shape and that might fix your phone. Otherwise, it's probably beyond the ability of an amateur to repair.
Nov 06, 2009 | Nokia 6310i
G900 touchscreen not working
Alright, i know this is old, but i hope i can help those guys/gals, i recently bought the phone and i had this problem too, i dont know if it will work, but its worth a try, when i tried everything, i started losing hope, but i tried knocking the phone on something soft like a towel or the bed mattress, then it works wonderously, and i heard some people accidentally dropped their phone on the ground etc, and it works like normal again... although i would never recommend dropping the phone on hard surfaces, just try knocking on your bed mattress (do not EVER knock on the metal area, im not responsible for any damages), or put a towel on your lap and knock it few times with the screen face down (of course, just knock slowly, dont put too much pressure...) hope this helps!, and sorry for the long phrase of boringness!
Oct 22, 2009 | Sony Ericsson G900 Smartphone
I Bought my nokia 5220 from india but now in canada i am getting very weak nework signals. Any idea to improve reception in canada
HI friend ,
this happens when you have not changed the network settings.
Network settings-> Search networks Manually->selet the service provider in canada(mostly Bell Canada has got the strongest signal strength) so it may be of help to you.
This will surely solve your issue!!!
Thank you for giving me a chance to help you out:):):)
And please vote/rate me so that I can improve myself and be of more help to you:):):)
Prasanth83:):)
May 14, 2009 | Nokia 5220 XpressMusic Cellular Phone
My Motorola W385 from MetroPCS has a White Screen
It should be dry "after few years", Probably is time to get a new phone.
Mar 27, 2009 | Motorola Mobility W385 Cellular Phone
No sound after dropping S350.
Probably one of two things:
The dropped caused the speaker leads from the PCB to Speaker to disengage (check the earphone jack, too... 'cause it is in the circuit)
or
The bounce cause the Audio amplifier IC to become desoldered from the PCB.
Mar 06, 2009 | Grundig S350 AM/FM/SW Radio
Sim card problem
The problem is with ur SIM.
Replace the SIM with same number.As it is much older AND may have scratches.
Jan 21, 2008 | Nokia 7250i
Son dropped TV
Chances are is that the actual screen inside is broke, so that the laser cannot display the correct colors in the right spots. First talk to a TV repair guy, but he will probably just say to buy a new tv.
Feb 12, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Nokia 3315 Cellular Phone Logo
93 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
