Question about GE Energy Star WCVH6260F Front Load Washer
Clothes softener does not drain out of the holder
I have tried taking the holder apart and cleaning it, but nothing helps. When I finish a load of washing, all of the fabric softener is still there.
  • 1 more comment
  • Anita
    Anita Oct 07, 2008
    Fabric softener doesn't dispense properly.  Then I have to remove the water that gets stuck there, but the same thing happens over and over again.
  • Anonymous Oct 25, 2008
    I still have softener there from weeks ago. I can't seem to get any help concerning this!
  • Anonymous Jan 06, 2009
    On softener rinse the liquid does not enter into the washing machine. Dont know why and cannot get i to work. Have cleaned everything????
Do your clothes smell funny? Does it take forever for a load to wash? That happened to me and there was a wire loose in the machine somewhere and it would quit mid cycle and never finished a rinse or spin cycle. My fabric softener never drained either!
Posted on May 28, 2009
Clothes have lint on them when the washing cycle is finished is there a lint area i need to clean
The newer Whirlpool top-loaders have lint screens on the inner tub and not accessible. These are supposed to self-clean during the drain cycle. I've heard that liquid fabric softener and detergent build-up may clog the screens when lint sticks to the gooey screens. Try something that will cut the goo like vinegar or ammonia in a small load level without clothes. Without clothes in the washer, that is.
Older Whirlpool washers have lint filters located above the tub, on the lid opening.
Good luck from Detroit, MI.
Jul 18, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
My washer cannot wash off liquid fabric softener so good. Some softener sticks into the clothes. Guess the the bottom of dispenser needs cleaning or maybe theres a lot of fabric softener left under it. How...
Hope this helps.You need to remove the washer to see whether debris blocked drain hoses.there might be clothes metal that blockes the drain hose..Hope this helps.
Jun 19, 2011 | Maytag PAV2300 Top Load Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Cleaning Fabric Softener Dispenser
it does come apart it is stwited in from the bottom up . but you can soak it in some hot water and shake it it will come clean after a bit
Jun 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water colects in lid sometime during the cycle.Drains onto washed clothes when lifting the lid to remove clothes. Water seems to be combined with fabric softener. Bleach holder also is filled with water....
I had the exact same problem. The problem is that your fabric softener dispenser is clogged up with a lot of dried, sticky fabric softener. The flooding comes from the part of the cycle when water that is to be flushed through the fabric softener dispenser can't drain properly so it spills into the bleach dispenser and onto the top and into the lid gasket as well.
To remove the dispenser for cleaning, you need to open the top of the washer. (First pull it away from the wall.) Carefully pry off the little emblem in the front center of the washer lid. Then remove the screw. Then slide the top forward to you about a 1/2 inch and prop it up carefully.
You then need to remove both hoses that are attached to the bleach and fabric softener dispenser (part of the same unit). Then unsnap the combined unit from the washer top. Then clean all the gunk out by running it under scalding hot water in the laundry tub and swirling the gunk out. Don't attampt to remove the blue round fabric dispenser part from the unit.
Put it all back together and you're good until you clog it up again with too much fabric softener; maybe several years again.
Good luck.
Mar 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
May 23, 2009 | LG WM1814CW Front Load Washer
The fabric softener tray is full of water when wash has finished
The 2 probs could be related.
The first you need to do is remove the dispenser drawer, and thoroughly clean every part of it, particularly the conditioner compartment, poke clear all the tubes and apertures you can see,the problem is caused by a blockage.
The smell is related to the fact that the waste pipe is probably connected to your sink waste, you need to remove the pipe and check for partial blockage, or if it goes to an outside sink , then you need to get some kind of drain cleaner to pour down the sink..
Also , at least once every 6 weeks do a hot wash with powder, but no clothes in, this helps to keep the m/c clean and prevent build up mould and dirt inside the m/c..
Clean the door seal regularly, when you finish a wash.and leave door open and dry it
This should help disperse the smell.
Plz rate my solution.
Dec 30, 2008 | Hotpoint Ultima WD72 Front Load...
Washer not always draining
It sounds like you have a couple of things going on here. First of all, the most common problems associated with a poor drain on a washer is due to clogs in the pump and/or drain hose. But first, make sure you don't have your drain hose shoved down in the drain standpipe too far. If you don't leave an air gap for the drain hose, this will often cause poor drainage problems and/or siphoning of the water as it tries to fill (this may be a cause for your soapy clothes, too). The drain hose should rest inside the standpipe so that pipe is not sealed and the hose is not sitting in the drain trap. You can check your drainage also by connecting a wet/dry shop vac to the drain hose and try to pull water through it from the machine. There will be some residual water that remains in the tub after washing. Just follow these simple steps: 1. Unplug machine. 2. Remove the lower kick plate under the door. There will be a screw in the bottom corners of the panel holding it on. 3. Find the drain pump. It will be on the right-hand side and is usually white in color. The drain hose from the bottom of the tub will be connected to it. 4. Remove drain hose from standpipe and connect a wet/dry shop vac (if you have one) to the end of it. 5. Turn vacuum on and watch the drain hoses from the tub and from the pump. If the hoses collapse, you have a clog somewhere. 6. Remove the drain hose leading to the pump. Check the impeller area of the pump for debris. This is usually where coins, clothing labels and other items get caught. 7. Clean out the pump and drain hoses. 8. When finished, reconnect any drain hoses that you previously removed making sure you get a good seal with the hose clamp BEFORE you fill the machine. If you notice a leak during fill, hit the "CANCEL" button to stop. Make sure you place the drain hose back in the standpipe too. Now...dispenser problems are usually the result of fabric softener and mildew. If you remove the dispenser tray from the machine and look inside the compartment on the front of the washer, you will notice a series of small holes in the overhead portion of the cavity. This is where water gets dispensed into the tray and flushes softener, bleach and detergent into your wash. If these holes get clogged, the tray will not dispense properly. Take a rag and clean this area thoroughly using some hot water. The water will need to be warm enough the melt any fabric softener residue that may have accumulated over time. Next, clean the area really good with some bleach solution to get rid of any mildew. You may have to use something to clear all the holes of debris. Often fabric softener is the culprit and it cakes the holes up. A simple wiping down with a rag may not be enough to do it. A cotton swap of tooth pick works great at cleaning these holes. This is also a good time to take the dispenser tray and soak it in some hot water in the kitchen sink to clean it out as well. Good luck to you and let me know if you find this advice helpful.
Aug 13, 2007 | Kenmore 43142 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
363 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
