Question about Garmin nuvi 350 GPS Receiver
Nuvi 360 cannot acquire sattelite
I've update firmware, done a hard reboot and can not get my Nuvi 360 to acquire sattelite - Garmin wants $200 to reburbish, any other suggestions? - Thanks!
  • 2 more comments
  • ltalessi Oct 06, 2008
    Hi Jim -- thanks so much, your guidance worked like a charm and provided a great perspective for troubleshooting the issue in the future. I really appreciate you help!
  • gvasuus Nov 16, 2008
    I have Nuvi 350. I upgraded the firmware and thought because of old map software, it is not working. i also purchased the upgrade and still same condition. Only thing is that at the end of updating, indicated there was error in upgrading. but when looked at the map software in the GPS indicates 2009 (latest one)
  • Anonymous Nov 26, 2008
    I had the same problem and then followed the advice and it worked like a charm! Thank you!
  • korovilas Apr 22, 2009
    Hey Jim, I also have tried all that was suggested. But the external antenna does not pick up any satellites either....no bars at all. I get a reading of 3.0 in the GPS S/W section. I sent garmin a email and they stated they would fix the problem for 85 dollars but it seems like a waste since the unit cost me around 135. Is there a loose wire I should be looking at or is it a firmware issue?
  • Garmin Master
  • 2,124 Answers
There are a few things you can try to restore satellite reception.
1. place your finger over the lower left-hand corner of the screen and hold it there
while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings. This will clear some of the memory allowing your Nuvi to collect new satellite data. Your Nuvi should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
Make sure the antenna is up and that you are outside. On the main screen, you will see a satellite bar graph in the upper left-hand corner. Touch the bar graph and you should get a satellite map, showing the satellites. If your Nuvi's receiver is working ok, you should see horizontal hollow bar graphs appear on the right. Eventually they will turn solid blue. This indicates they have downloaded the proper data from the satellite. When you have (4) solid blue horizontal bars (4 satellites), you will see the top panel begin to show improved accuracy and your Nuvi will then work as it should. This entire process make take 30 minutes or less.
If you don't see any bar graphs, your Nuvi may ask you severl minutes later, if you are indoors. If your outside, select no. It will then ask you if you have moved 1000 miles since your last use. Select yes. This will cause your Nuvi to start looking for
satellites, trying to locate your new position.
Now, if you still don't see any bar graphs, then your antenna may have a problem. There is a known issue with the Nuvi antenna where a part has failed, causing the Nuvi to no longer use its internal antenna and it's now always looking for an antenna at the external antenna port (the gold connector on the side of the Nuvi antenna). If you have a piece of small wire, a couple feet long, you can insert that into the center lead of the external antenna jack. Most likely, you'll begin to see bar graphs after a few minutes and your Nuvi will lock.
I haven't been able to identify yet, which part has failed. I am working on that.
However, if the piece of wire works, you can always go on eBay or a retail store and
purchase an external antenna for your Nuvi. They are magnetic and can either stick to your roof or any metal surface within your vehicle.
Here's another way to determine if your antenna has failed and will have to be replaced:
At the main menu, pres on the "wrench" symbol. Then press the "gear" symbol and then press "about". There is a field marked "GPS S/W". There should be a number next to it. It may be "2.9" or "3.0". That is good. That tells you that the main board in the GPS is communcating with the antenna receiver. If you see "0.0" then your antenna is defective and there's no way to repair it other than replace it.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Oct 03, 2008
  • SHARCNET-USA
    SHARCNET-USA Oct 06, 2008
    Your welcome!
    Best wishes & safe travels,
    - Jim
  • SHARCNET-USA
    SHARCNET-USA Nov 17, 2008
    If you tried the above procedure and you still can't receive signals, then yes your antenna needs replaced.
    - Jik
Dude I wish I could thank you personally. Tried everything for days with this problem. Nothing worked and was about to break this thing in pieces. Tried your piece of wire advise and IT WORKED !!!
hahaha god bless you man.
Juan.
Kennesaw, GA
Posted on Mar 18, 2009
Thanks for the good info. What is the GPS S/W is reading 2.9, but it still wont acquire sattelite is the entenna bad?
Posted on Nov 10, 2008
Have accidently wiped mapping from garmin sat nav
I can help you fix your Garmin Nuvi 200.
The error message you are receiving about maps is actually a sign of a firmware corruption problem, which just happens from time to time with electronic devices. Updating the firmware of your nuvi will replace the corrupt firmware.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software. Occasionally a nuvi 200 will also need a Hard Reset (preceded by a favorites backup) to bring it back to 100% operation.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 09, 2010 | Garmin nuvi 200W GPS Receiver
Nuvi 660 cannot acquire sattelites
do a proper reset like take the battery out if its optional then press the power button for 30 seconds without connecting the power,if that doent help then you need to reset the software to the factory setting thorugh the menu itself.
Jul 04, 2008 | GPS
Tip
Garmin Nuvi 200W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 200 and 205 series GPS unit.
I hope that helps.
Backup & Restore Nuvi Favorites here.
Download Nuvi 200W Manuals here.
Download Garmin WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Garmin Nuvi 200 Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
I hope that helps.
Download Nuvi 200 Manuals here.
on Apr 17, 2010 | Garmin nuvi® 200 Car GPS Receiver
Garmin Nuvi 200 - continually updates firmware
I can help you fix your Garmin Nuvi 200W. You will find the newest version WebUpdater if you follow my links, released March 31, 2010. I think you will find between a Hard Reset and the new software, your Nuvi will be better than new again.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 22, 2010 | Garmin nuvi 200W GPS Receiver
SLow to acquire satellites after being turned on in the car
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Dec 07, 2009 | Garmin nuvi 200W GPS Receiver
Ive been getting the message ''acquiring satellites'' since yesterday morning
I hope that helps.
___________________
Dec 02, 2009 | Garmin nuvi 200W GPS Receiver
I have a nuvi 200, less than 2 yrs old. Has probkems acquiring satelite. Has GPS sw 2.50b and audio 2.20. Also, where and how much is usb adaptor that fits to left side of unit (special plug in to unit
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W.
The usb cable you require is a standard USB to mini-USB cable. MP3 or camera cables will work.
I hope that helps.
___________________
Oct 14, 2009 | Garmin nuvi 255W GPS Receiver
Garin nuvi 200 cannot aqcuire sattelite
I hope that helps.
___________________
Oct 08, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
451 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
