Question about Platinum Norstar T7208 Telephone
Unlocking my Nortel T7208
I can't retrieve messages on my phone. Everytime I dial feature 981 or the mailbox feature it says enter password, I do that and then it says I'm blocked and that I should contact my Admin. Is there a code I could use to unlock this phone and bypass the password ?
Thanks,
Neka.
  • tlc_betty Nov 13, 2008
    mesages blocked sayt to contact admin
  • hrussell65 Feb 09, 2009
    My password also expired. When I attempted to change it, the mailbox locked and it won't unlock. It says on the display to "Call Administration." I have tried looking for an easier solution online.
    Thanks for any help you can give.
3 Suggested Answers
SOURCE: i have a similar problem.
Press feature 985
Extension of vociemail is displayed. Dial 9
PSWD: RESETSMPSWD (73738767793)
Reset PSWD? Press YES
Login will be changed to default (1020000 for 3 digit EXT's or 120000 for 2 digit)
Posted on Jul 09, 2009
consultel1
  • 860 Answers
SOURCE: password issues
To reset a subscriber mailbox press feature 983, enter in log (default 1020000), on the 3 soft keys bolow the the screen press mbox,chng, enter extension number of the locked mailbox, press reset at the reset password prompt.press rls key
Posted on Oct 09, 2009
  • 53 Answers
SOURCE: I'm locked out of the
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you the extension of the phone you are using.
Posted on May 13, 2011
How to program nortel T7208 to have feature > 981 with an "other" option
After entering the mailbox access F981, press "#", the display should change from Pswd: to Log:. Now, enter the alternate mailbox number followed by the password for that box and "#". The remainder of the prompts should be the same as accessing the 'native' mailbox.
Nov 14, 2012 | Nortel Business Series Terminal T7208 -...
My MBOX is locked on my T7316E Nortel phone. Also, trying to retrieve messages from home I somehow changed the password and I don't know what it is.
Feature 985 will show you your mailbox extension
Apr 25, 2011 | Nortel T7316E 2-Line Corded Phone
I'm locked out of the voicemail feature and I can't find a way of activating a new password to pick up messages. It's a Nortel T7208 system. Has anyone any ideas?
Feb 18, 2011 | Platinum Norstar T7208 Telephone
HOW TO RETRIEVE VOICE MESSAGES? DOES THE PHONE DISPLAY YOU HAVE A VOICE MESSAGE? IF NOT, THEN WHAT IS THE FEATURE CODE TO ENTER AND OBTAIN MSGS.
The display on a Nortel set will say "message for you" if there's a message in your mailbox. To access your voicemail you can press your open voicemail key if its programmed or press feature 981.If you wish to retrieve your messages remotely, call your office, when the autoattendant answers the call press ** followed by your extension number, your password then # (ex. **2231234#).
Jul 09, 2010 | NorStar M7208 Corded Phone
Setting up the Voicemail on a Nortel T7208
your mailbox number is the last 4 digits of your phone number
Apr 26, 2010 | Nortel Business Series Terminal T7208 -...
My phone is Norstar M7324. I can't get voicemails. I have customers called and left voicemails but I can't receive them. I use Feature 981 and it tells me no messages everytime. Any advise? Thanks.
Maybe the callers are leaving messages in the General Delivery mailbox? From your phone, dial Feature 981, when it prompts you for a password, press the button under "OTHR", and you will be prompted for the log. (The log is the mailbox and password combination for a mailbox not assigned to your phone.) If you use 2-digit extensions, the General Delivery mailbox is #10, for 3-digit extensions, the mailbox number is #100, and etc. The default General Delivery mailbox password is "0000". So, using 2-digit ext's, the log would be 100000, then press # or OK and you can retrieve the messages. Write back if you need more help.
Mar 16, 2010 | NorStar M7324 Telephone
Password issues
Oct 09, 2009 | Platinum Norstar T7208 Telephone
T7208 nortel network general voicemail locked
Generally, you dial feature 981 to get in, then extension number and password. If you have no new messages it will say that, then give you the option to review old messages. To delete a message you press 76. If that doesn't work, login to your mailbox, press 8* then 6 to get to "go to message" then press the message number and #. If you have an on-site administrator, they can delete your mailbox as well, otherwise you will have to call your tech help service and have them erase it remotely.
Jan 21, 2009 | Nortel Business Series Terminal T7208 -...
Retrieve a message
Depending on what VM system you have there is a feature # you key in.
For instance the Nortel Callpilot feature is "feature, 981" If this is your first time logging in you will have to enter a password. Contact your systems administrator to reset or set your password to never ask.
Aug 22, 2008 | Nortel Meridian M7208 Corded Phone
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
Platinum Norstar T7208 Telephone Logo
2,094 people viewed this question
Top Platinum Lands Phones Experts
Are you a Platinum Lands Phone Expert? Answer questions, earn points and help others
