Question about Gateway GTW-P42M303 42 in. Plasma Television
Gateway tv is down, blank screen, no sound , no buttons work
So you posted that you can fix this...help me..how?
No sound no image
Posted on Oct 09, 2008
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
Help pls - toshiba 40bl702b Silent / No sound for a week!
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Apr 24, 2015 | Toshiba Televison & Video
Blank Screen
If it has sound, then its back-light has failed which is a service engineers work but may also be related to a screen fault in which case a new set is needed as cost of repair makes it not worth it.
If no sound then dare I say worse and mostly if more than 2 years old, not worth it, sad to say as parts do not linger very long other than major brand names most are generic badges on economy sets.
Hope this helps..........
Nov 24, 2017 | Vizio vm190xvt 19 in. TV
My 42 inch philips (42PFP5532D) has blank screen but blue light to show its on but nothing on screen :(
just let me know if their is a sound when you turn on the tv then the only problem is black screen. if you can get sound tried to press the channel up/down button let see if you can get a channel. if you hear that receive channel that was mean the problem is either the screen back light get busted or the power inverter is defective. hope this can help good luck.
Nov 02, 2012 | Televison & Video
My Sanyo HT28745 28" HDTV clicks but doesn't turn on
I have had a similar problem with my tv, it has something to do with the power supply.Try unplugging your tv from the AC outlet. While unplugged from the power supply hold down the - volume control and then plug the tv back in while holding down the - volume control. It should bring up the service screen. If the screen turns on and is blank then it may need to be brought in for repairs.
If the screen does turn on, either blank or with the service menu, turn off the tv and unplug it from the power supply again. With it still unplugged hold down the power button on the tv and then replug in the tv. continue to hold down the power button until the tv displays a video signal on screen.
Feb 02, 2008 | Sanyo HT28745 28" TV
Gateway plasma tv
I was able to resolder the pin shown in the picture and it fixed my problem as well.  I also used a razor and cut off the last socket for that pin on the connector and put a dedicated connector on so that it will take the heat a little better.  Also when I re-soldered that pin on the bottom side of the board I scraped away some of the protective coating around the solder puddle so that I could make a bigger solder puddle to add a little more strength and heat resistance.
Dec 26, 2007 | Gateway GTW-P42M303 42 in. Plasma...
Image dissapears but there is sound
My sister owns this unit, and like other users on this post, her screen quit working on her. She brought it over to me to see if I could fix it before she tossed it out. I first hooked the unit up to the TV with supplied A/V cables to see if the unit was outputting video. The unit supplied video to the TV fine, so I figured the problem was with the LCD screen or the connection from the unit to the LCD.
Like another user on this post, I noticed that the video would come on for a second or two when the small depress button was pressed, but then go blank again. (This button is at just below the LCD screen on the base unit – toward the middle of the base unit. You can see there is a small notch on the LCD screen that fits into this depress button when the unit is closed. This allows the unit to know when the LCD screen is closed.)
Here comes the fix that worked for my sister’s unit – I hope it works for yours also. . .
I decided to reset the screen to the factory settings through the setup menu. This is difficult to do when the screen is blank, so I figured I would have to go hook the unit up to the TV again in order to see the setup menu. Well, I had already put the AV cables away, and I felt too lazy to dig them out again. I decided to just navigate the setup menu by pressing the depress button on each menu, which the second or two of video would give me ample time to navigate the menu. Once I was in the first setup screen and depressed the depress button the screen came on like it had been doing when I was trying to view a movie, but low and behold it did not go off like it had been when trying to view video. Since I was in the setup screen I decided to reset the unit to factory default. I then exited the setup and played a movie. The screen did not go off. I have tried to get the screen to go blank again, but it stays on. It sounds like the problem is not with the LCD screen or its connection, but rather with the operating software of the unit. It is a piece of junk, but it is working for now. I hope this helps with your units also.
I also noticed some users posting a problem with an upside down screen. Hold down the mode button and the screen will cycle through different settings … one of which is upside down.
May 02, 2007 | Polaroid PDM-0723 Portable DVD Player
Screen is blank with sound working
i just fixed mine by doing this. on the remote there should be a button that says f. hold down the f button then press mute and that should work it did for me
Apr 02, 2007 | Polaroid TTM-2003 Combo
Gateway GTW-P42M303 42 in. Plasma Television Logo
139 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
