Question about HP Office Equipment & Supplies
Printer is not respponding to commands from the computerI have checkedusb & power leads, turned it off,put in a new cartridge & it still is not printing. All lights on control panel are on.
  • HP Master
  • 1,879 Answers
Disconnect the printer from the computer to isolate it
turn the printer OFF and check for any obstructions inside
now turn the printer back ON while still disconnected from the computer and observe the lights
since you already replaced the inks and if all the lights are still flashing, it's already a hardware failure.
Posted on Oct 03, 2008
Put new cartridges in my canon mg5250 only printing black and yellow no other colours
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Oct 18, 2011 | Office Equipment & Supplies
My i550 won't print When I turn it on there's a short grinding noise Then there's a short green flash, then short orange, short green, short orange then longer green This cycle then keeps...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Aug 18, 2011 | Canon BubbleJet i550 InkJet Printer
My printer will not print. The check printer cartridge light is blinking. I just put a brand new ink cartridge in. What else could be the problem?
Aug 08, 2011 | HP PSC 1410v All-in-One Printer
Hp all in one printer office jet 4215 carrtrage error put new ink in and shut it down
Aug 02, 2011 | HP Officejet 4215v All-in-One Printer
How solve the problem for hp offijet 3608 catridge error problem & disply the refer to documentation for truobleshoot
Jul 28, 2011 | HP J3680 Officejet All In One Printer
Power down
try removing the printhead and turning on power, if it works you need a new printhead.
QY6-0070-000 around $40.00
Jun 18, 2009 | Canon PIXMA MP520 InkJet Printer
HP Deskjet D2360 Printer
Cartridges have small electrical contacts. It sounds as though either the cartridge is faulty or it may have got stuck in the wrong place.
Firstly turn off the printer.
If you are using it with a computer via a usb connector, disconnect the lead from the printer.
Disconnect the power lead from the printer.
Lift the lid to gain access to the cartridges.
Ensure they move freely along the track from right to left.
Remove the cartridges and re-insert them one at a time.
Close the lid, reconnect the power lead and USB connector.
Switch the printer back on.
If you are using it with a PC, your computer should automatically detect it after a few seconds. If it doesn't then restart your PC.
If this does not clear the problem, try new cartridges. If it still does not work, the printer may have a control fault.
Hope it works, good luck!
Jan 22, 2008 | HP Deskjet D2360 InkJet Printer
42 people viewed this question
Ben Johnson
