Question about Magnum S9 Base CB Radio
Magnum s 9 sideband fault
On lsb needle swings up to 9 on receve but no output
usb.needle swings up on tx without modding but i can be herd
thanks for your time .
from ian .nelson lancs uk
wilsonian77@yahoo.com
  • clive pearson
    clive pearson May 11, 2010
    you say when you switch to Low side band the sound cuts out ie recieve signal ?. Sounds like your transmitting but not recieving
    however if this is the same on all other settings it is possible your audio output chip has blown , without actually looking at the set it is a difficult one to diagnose . I am sumising that you have normal opperation when the Lsb is off therefore we can rule out the audio chip .. and focus on signal in in that case the possibility is the switch on your set is faulty or the low sideband module has gone faulty either way i think you should check with your local Rig doctor to fix this problem ........hope this is helpful Regards Vortash
    Problem Solver:
  • 5 Answers
Sounds like tuning, have you been through the alignment procedure? take a look at cbtricks.com for the info
Posted on Jun 25, 2009
No transmit on usb.only recive but all works on am and lsb.1stGen.pres.whst
the transmitter section of the radio needs to be aligned you need to look for a cb shop its nothing you can fix on your own
Mar 28, 2014 | Radio Communications
Usb audio
need to put it on an oscillascope and frequency counter and have it aligned. even taking to a shop should be less than $45 to have it fully done.
Mar 21, 2014 | Magnum Radio Communications
Have a Magnum 257HP 10 meter radio. While connected to a 50 ohm dummy load, and a power meter, noticed that the USB and LSB would not modulate when a voice input is placed into the microphone. Also, on...
You may have a radio where the AM limiter has been defeated which can cause all kinds of issues. I would first check the mic is wired right and does not have a problem, the radio should have output with a tone to it on sideband--wattage up to over 20 watts on SSB is normal.
Dec 12, 2012 | Magnum Radio Communications
Cobra 148 gtl-st wont transmit but receives great
Check first your microphone
• check if TX is engaging when PTT is pushed.
• check for continuity ( mic and cable )
If you have not done these steps,
try it first, or borrow other compatible mic for Cobra 148GTL
from your friends on air.
Jul 28, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
My cobra 148 work well on am but not on lsb
clipping the limiter should not have prevented tx on sideband are u sure u didn't do something more accidently. r 131 is the correct limiter for the 148. just out of curiosity what year 148 is it?
Jun 15, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
How to use ssb usb am cb radio
  • Well, AM is Amplitude Modulation and Sideband suppresses the carrier and uses only the top half (upper sideband) or lower half (lower sideband) of the wave.
  • Whether using AM, USB or LSB you are on the same frequency although if someone is on USB and you are on LSB you will not be able to understand what the other person is saying because you are using different parts of the wave. So 27.185 (channel 19) on AM, USB or LSB is still 27.185.
  • If you have further questions please let me know.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,
Tony
Oct 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Magnum 257HP ,Poor TX audio , tried several mics ,SSB ALC , Bias no effect . Did not align TX lower stages . AM , FM are perfect , all RF power outputs perfect , looks good on scope with generator but...
That mod that magnum does really ups the sensitivity. so much thats is too much. If that model has a switch for the compressor turn it off. It will help 100% and make it sound decent not twangy and over modulated. Just the design of these newer exports are not like the old ones.
Dec 14, 2010 | Magnum 257 CB Radio
Rci 2980 no modauliton on am/lsb/usb/fm.but good recived. and good output.on am.
is it steady output on AM with no modulation swing. then change the Audio transistor. SSB should work. they feed straight through to rf final. if no modulation on either mode, then check the mic, audio ic preamp.
Nov 26, 2009 | Radio Communications
Superstar 3900 with no USB or LSB on receive.
most likely been fiddled with and out of alignment. If you have a freq counter and a volt meter you could possibly fix it yourself. look at cbtricks.com for the aligment procedure.
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Magnum S9 Base CB Radio Logo
344 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
