Question about Linksys Wireless-G WRT54G Router
Hard disk Drive
I have a HP Pavillion dv1000 notebook which is two years old. HP diagnostics stated the hard drive is shot and needs to be replaced at a cost of $496.00 Is there any way that I can run another check to see if the hard drive is indeed in need of replacement.
  • mj49938 Oct 03, 2008
    I ran the scan disc program. It does not show any problems. The computer itself is not making any type of strange or out of the ordinary noises. I did have a problem when I went to do a download of windows pack3. My system crashed and I lost all data on the computer. Seems I have been having problems ever since. I also thought the price they were asking was outragous.
    MJ
    I have not been able to find the brand of the hard drive
    Novelist:
  • 169 Answers
Wow! I'm not sure where the $496 number came from, but that's literally insane! You can purchase a 120GB notebook drive from NewEgg for $49!
If you can get into Windows, right click on your "C" drive and go to Properties, Tools, Error Checking. You can have Windows scan the disk and automatically fix errors. Personally, I turn the "auto" option off, as I want to see what damage (if any) is done ..but if you think the drive is really bad off, or don't care as long as it's fixed, then check that option.
If you can't get into Windows, you can have a local PC repair guy test the drive outside your tower, using an external drive (or a friend can do this as well, using the "Error Checking" I mentioned above).
Generally, if the drive isn't making clanking sounds or making metallic noises, it's probably "fixable".
If you MUST replace the drive, shop around first and don't assume that because one person quotes you a price, that's what you have to pay. Replacing a hard drive is one of the easiest upgrades to perform on a laptop. If you spend over $100 to do this (including having someone do it for you), then you are nuts :)
Hope this helps - please remember to rate :)
Posted on Oct 03, 2008
  • 63 Answers
Do you know what brand the hard drive is? Most of the hard drive companys have there own software you can download from there website for free. If you tell me what the brand is ill link you to the download.
My HP pavillion dv1000 is painfully slow and unworkable, am trying to restore it to factory settings but do not have the discs
you could purchase the discs ,theyre not that expensive "ebay"for example but you would /might need an external drive
Mar 10, 2011 | HP Pavilion dv1000 Notebook
Hp 6720s it says non-system disk or disk error
Hi,to confirm if your drive is still functional please go to BIOS,by press F10 when the system has just been switched on,go to Diagnostics on the Bios Menu,select Hard Disk test to verify the state of of your drive,if after test drive is still ok back-up files and format,if not replace drive.
Jan 08, 2011 | HP Compaq 6720s Notebook
Hard drive crashed
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer.
  1. Plug the AC Adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  5. Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
NOTE:
The exact wording of the option for your particular BIOS may be slightly different.
The Hard Drive Self Test performs a Quick Test followed by a Comprehensive Test . During each test, the window displays a status bar and an estimated time to completion. See HP Notebook PCs - Testing a Hard Disk using the Built in Self Test for additional information.
  • If any test fails , contact HP service and support for instructions on how to order a replacement hard drive.
  • If all of the tests pass, the hard drive is not damaged. As a rule, HP will not replace a hard drive under warranty that does not fail the HP Hard Drive Self Test.
  • If there is no physical problem with the hard drive or memory, then try reinstalling your Windows operating system to troubleshoot the problem.
If it fails then you need to replace the HDD. If you can provide me the product no. then I would be able to find the exact part no.of the HDD.
Dreamkam
May 28, 2010 | HP Pavilion dv1000 Notebook
Hp pavillion dv6915n - no hard drive detected
We do not say that the hard drive is damage maybe the IDE was faulty already. You may open your laptop and check the hard drive. Try to replace the IDE to check if the hard drive is good.
Mar 31, 2010 | HP Pavilion dv6915nr Notebook
HP Pavilion dv1000: hard-drive wont load OS
The arm that controls the head has malfunctioned. Your hard drive is probably toast. The more you run it though the more chance you have of not being able to recover the data on it. I have a Tip and Trick for trying to recover some of the data. You can read it here.
Please share it with your friends.
http://www.fixya.com/support/r3584465-bad_hard_drives_and_data_recovery
Dec 06, 2009 | HP Pavilion dv1000 Notebook
I have a hp pavillion ze5385us hard drive making all kinds weird sounds with stop:0x0000008E and vertical lines in center of screen besides a new hard drive can this be fixed andis this worth fixing?
You may have two problems, or just one.
The disk-drive is "failing" -- if it is "misreading" the "wallpaper" picture, then the viewed wallpaper will look to be "corrupted".
Backup all your files, to DVD-writable or USB memory-sticks,
before the disk-drive completely "dies".
Given that you have a "Athlon 64 3800+", it's worth replacing the disk-drive, reinstalling Windows, and restoring your files from your backup.
Much cheaper to replace the disk-drive than to buy a new computer.
Nov 27, 2009 | HP Pavillion ZV6000 Notebook
HP Pavillion dv4000 is stuck with a 'disk read error'
try with Disk Manager so Format with Low Level Format...run in under DOS
Oct 23, 2009 | HP Computers & Internet
Transfer data from a dead laptop to a new laptop
Do you have a usb to SATA connector? If so you can plug the old drive into the USB slot and it will act as a slave so you can pull the contents from the old drive to the new. The adapter is about 25.00 or If it was me I would invest into a pocket USB hard drive case that you can put your old drive into perminatly so you can always have a external hard drive for back up later after yo uhave moved the data over and reformatted it. The case is $25-$40.00.
Joe
Jan 16, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hp pavillion dv 1000 notebook
Hi can u tell what os is currently install in ur laptop..
Go to bios setup check whether ur driver is showing.
if its showing means go to boot device property and change the first boot device to Driver.And then try it..
Sep 16, 2008 | HP Pavilion dv1000 Notebook
Linksys Wireless-G WRT54G Router Logo
71 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
