Question about ASUS K8V-MX Motherboard
K8V-MX motherboard+HDD size limit
I have K8V-MX motherboard. I am planning to buy a 500gb internal HDD. I needed some help to decide before I make purchasing decision.
1) Can u please let me know what is the max size of HDD that it can support? (E.g.- can it support 500gb).
2) Does it support SATA
3)Which HDD should I buy(Say,which brand? and SATA/IDE? and HDD size-e.g.-550gb?)
Any help on thos would be greaty appreciated.
Regards,
Pras
  • sanu_satish Mar 11, 2009
    I am also looking for any suggestion ...
  • 1,031 Answers
Yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Posted on Oct 03, 2008
  • Starnley Johnwells
    Starnley Johnwells Oct 05, 2008
    Check your BIOS. There's a setting there to change the Drive controller which allows the SATA drive to be recognized.also check the manual i gave you through the link
    In the bios the SATA operation setting should be set to ATA mode.
    Check for similar setting in your bios for the mode
    In the bios the SATA operation setting change it to ATA mode.
    Check if there is a setting in your bios for the mode First off, many of the on-board SATA controllers are configured as RAID controllers. If yours is one of these, the first step is to enter the SATA BIOS setup and configure the SATA drive as a single volume RAID array.
    The details should be in the user manual for the board.
    Next, you often need to install the SATA driver while installing Windows.
    Check the driver CD that came with the motherboard, or download the driver from .hope this helps
I have a question as well and any help would just be that help.
I am trying to install a 750g SATA HD on the ASUS KV8 motherboard and its not recognizing it.
When I go into the SATA raid set up, it wont let me do anything but answer (Y/N) then EXIT. Keyboard is dead
Any suggestions?
Posted on Jan 17, 2012
  • ASUS Master
  • 6,487 Answers
This motherboard can support up to 500GB size of hard drive, and yes its does support SATA so if you will be buying a new hard drive a recommend you get a Sata hard drive from Seagate or Western Digital they are very reliable when it come to storage durability and dependability, so go ahead buy a 500GB SATA hard drive.....
Hope that helps...............
What is the maxium hard drive will my k8v-x support
You have to limiting factors when determining max HDD size. 1) IDE or SATA interfaces. 2. 32 bit or 64bit Operatings System. With a 32 bit OS you are limited to 2TB per drive. Although I think 500GB is the largest IDE drive you can get.
Nov 23, 2011 | ASUS K8V-X Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
How much r support internal hdd size..........? i attach 2 hdd { 1_160gb (2) 500gb,,then pc don't run ....... so pkease give me answer on my id..i.e........... bipin.bihari90@gmail.com
The limit for Pentium 4 motherboard is 250GB only for INTERNAL HARD DISK DRIVE and it will not work on 500 GB Hard disk but still you can use it at external hard disk drive.
Dec 09, 2010 | ASUS P5GC-MX/1333 Motherboard
Amd k8v-mx can suppor 500gb hard disk?
Yes of course that motherboard will support a 500GB hard drive.
Regards.
Aug 26, 2010 | ASUS K8V-MX Motherboard
I have K8V-MX motherboard. I am planning to buy a 1TB SATA HDD Will this support ? Thanks! Madhusudan
Your model KV8-MX motherboard does not have a SATA controller.
To install a 1Tb SATA hard drive you need to install a PCI SATA controller and then connect the SATA hard drive to this controller board.
Aug 21, 2010 | ASUS K8V-MX Motherboard
PATA SATA PROBLEM
This motherboard does support SATA. Check out the specs on the ASUS website:)
http://www.asus.com/products.aspx?l1=3&l2=14&l3=225&model=754&modelmenu=1
Dec 30, 2008 | ASUS K8V-MX Motherboard
Unrecognized HDD-- need help!
You could also try setting the jumper on the hard drive to "limit to 1.5gb/s".
Oct 04, 2008 | ASUS K8V-MX Motherboard
Sata driver
check for the website of your HDD vendor.eg-www.seagate.com for seagate hdd.
make sure you format using fat32 file system.
Jan 28, 2008 | ASUS K8V-MX Motherboard
ASUS K8V-MX Motherboard Logo
1,316 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
