Question about XO Vision XP78 7.8 in. Car Monitor
Model#: GX2262 do i need cut into my headrest to use this monitor, how does it work Model#: GX2262 i dont have whats listed in the model box, it would nt let me put in what listed here
How do I remove the headrests on a fiat 500l so I can put on seat covers?
you dont,cut the cover and slide down over the headrests and sew them together
May 31, 2015 | Fiat Cars & Trucks
Do you have printable installation instructions for the Roadview RHM 7.0 headrest? We seem to have misplaced ours. Thank you
Headrests slots are different in many vehicles. You can take the slots out of your other car & install them into the SUV bit it is a pain to do. Most are sewed in. Take small edged knife with thin blade, cut down the side of the slot,close to metal so to cut the stiches holding it in place. Some use Glue. Then take out other slots from headrest in SUV, same way. If glued,thats good,just glue your set to use back in. If stiched,just buy Auto Uphostery Glue & use that. Will work. Good Luck,not easy task.
May 17, 2014 | Roadview RHM-7.0 Universal Replacement...
Universal Remote Control Numbers needed for NAXA TV Model NT-1506
0483,0291,0382,0957,0000. Check these codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 18, 2013 | Naxa Electronics Televison & Video
Message saying "no connection between PC and printer. Installed new USB cable and it works for 2 weeks, then "no connection notice again". Uninstalled and reinstalled Dell printer software and no help.
hi jaromarburge,
you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
Oct 12, 2009 | Dell 922 All-In-One InkJet Printer
Hello, Every time I try to print it just puts it on pause and it won't let me start it up again. Also if I try to get on to the user guide page it says "Cannot open file:...
hi jkearns92,
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
Oct 11, 2009 | Dell 924 All-in-One InkJet Printer
Scanner not working ... can't figure out why... need to scan my paycheck to deposit to bank but says scanner not connected (but it is) or not turned on (but it is) ... printer works fine, but scanner does...
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day. :)
Oct 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
My printer is not printing everything else works, computer says that the printer is not connected.
hi there,
have a great day :)
Sep 30, 2009 | Dell 922 All-In-One InkJet Printer
Want a RAV4 but the headrests are terrible!
I moved one of the headrests from the back to the driver's seat. Had to open the legs a little bit but it fit.
Something else I found is that if one adjusts the seat so that it cradles one's body, thus maximizing contact between the body and the seat, and then puts the headrest back on it does not pushes one's head forward. Seems they designed it to be driven as if one was sitting on a recliner.
Although one can drive comfortably in that position, the headrest is massive and blocks the view over one's right shoulder.
Sep 20, 2009 | 2009 Toyota RAV4
Connecting headrest monitors to Kenwood DDX-6019
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
May 10, 2008 | Sony XVM-R70 7 in. Car Monitor
XO Vision XP78 7.8 in. Car Monitor Logo
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
