How to connect my phillips freeline LS1300 series desktop to my laptop?
    Scholar:
  • 155 Answers
If you are trying to connect the desktop to the laptop just so you can access each computer from each, you will have to setup a 'local area network' on each.
You first have to check the hardware. Both computers should be connected to a router or to each other via ethernet cable. Make sure connections are secure.
To confirm if there is physical connection, get the ip address of each computer.
1. Go to Start>run. Type in "cmd" without the quotes. Hit ok.
2. In the command prompt, type in "ipconfig". take note of the ip address for each. If it starts with 169, that means there's is no physical connection. Check your cabling or tell me, how you have it setup. Otherwise, you're good.
Second, setup the software. I am assuming, both computers run on Windows XP.
Do this on each computer.
1. Go to control panel. Go to "network and internet connections".
2. Click on 'Network Setup Wizard' on the left pane.
Check these screenshots.
http://screenshots.leeindy.com/network_setup_wizard.shtml
Follow the screenshots and do the following.
Take note of the computer name that you will enter for each computer. You must make sure that the Workgroup Name is the same for both computers. It doesnt matter what name you enter or if you leave the default as long as both computers have the same workgroup name.
Now, that you have connected them, you have to create a portal for each computer to access the other.
1. Go to computer1. Right click on a blank area on your desktop wallpaper. Left click on new>shortcut. type in \(ip address of computer 2. it should look like something like this ---> \192.168.1.3
Put the computer name of computer2 in the shortcut name box.
Try to open it. It should open the shared folders in computer2.
Repeat this process on computer2, entering the ip address and name of computer1 this time.
This will let you access the folders stored on each computer from the other. Be sure to share the folder you want to access remotely.
If you want to access 'my documents' in computer1 from the other computer, Go to computer1, right click 'my documents' and click sharing. check the box to enable sharing.
Do the same thing on any folder you want to share on the originating computer.
Posted on Oct 03, 2008
What freeline ls2300?
put into google the make of your graphics card and download drivers
May 23, 2014 | Computers & Internet
I need to buy a internal hard drive for a Philips Freeline LS2200. Can you advise me if I need a 2.5 or 3.5 inches?
The Philips Freeline LS2200 uses a 320GB SATA Seagate, 3.5 inch width harddrive. (7200RPM)
The usual desktop sized harddrive.
Due to the low costs of SATA desktop harddrives, I would recommend at least a 500GB unit,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4499974&CatId=2459
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 24, 2011 | Computers & Internet
Thanks Miro70, what 3in high graphics card for LS1100 desktop
Actually you may have to shop around for a form factor that would fit smaller cased pcs. Try Tigerdirect.com.
Mar 17, 2010 | Computers & Internet
My Philips LS1100 freeline desktop PC is too slow ???
u need to change graphic card first in something better !!!
what games u want to play, tell me and I'll tell u what u need exactly !
Your RAM ??? It can't be 2.6G, but that is place to start, ram must be same brand and value, compatible with Your motherboard !
Feb 24, 2010 | Computers & Internet
How to get Philips freeline laptop out of sleep mode
if you want to disable sleep mode then go to control panel switch to classic view then go to power option change the turn off monitor to never and check it .............
Dec 10, 2009 | Computers & Internet
Where can i purchase a new 915p-m3 motherboard from a phillips freeline
HI...
You can purchase 915-m3 motherboard through online. Visit the ebay website and search the model and brand name.
Regards
PCmania
Sep 04, 2009 | Abit 915P (AG8) Motherboard
Phillips MT2100
I have seen a recent malware (short for malicious software) program that disables the cd-roms and prevents access to the c: drive by making registry changes. Go to download.com and download Malwarebytes and run it. It helped me get rid of this problem. This particular malware was pretty nasty as it prevented me from accessing the drives (no access through My Computer, Windows key + E (Windows Explorer) and access to it from the start menu was removed, and no USB drives either! I had admin rights and was still denied. The only way I could beat it was to boot into safemode with networking and download Malwarebytes. Try this first. Since you are using Peer to Peer software (Limewire) sharing you are a ripe target for viruses and malware.
Mar 19, 2009 | Computers & Internet
Philips freeline wireless keyboard and Mouse
Have you tried re-installing the software for the keyboard & mouse. It sounds like a driver is missing and the best way to solve it in most cases is to re-install the software from the disk that came with the Keyboard & Mouse. Hope that helps. Bud
Jan 05, 2009 | GE Wireless Optical Mouse
I have a philips freeline 1100 and have so many problems with it within 3 moths of purchas it has had a new hard drive ,fan, graphics board,ect; I now have the biggest problem with it it kept shuting down...
go to this link and read my blogs at bottom of page (my name is folkestoner) for information and help on Freeline LS1000s and LS1100s
http://news.digitaltrends.com/news-article/5985/philips-freeline-entertainment-pc-s
Oct 21, 2008 | Computers & Internet
Cannot open ls1300 base unit
These cases are very, very tight but after you loosen the 2 x hand turn screws and try to slide the case cover towards the back of the machine the case will eventually slid off for access.
Aug 28, 2008 | Computers & Internet
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
