Question about Epson Stylus Photo RX700 All-In-One InkJet Printer
HOW DO I CLEAN THE WASTE INK PADS ON MY EPSON C20UX
BROUGHT A NEW PRINTER THANKS ANYWAY.
Posted on Oct 04, 2008
How do I reset the waste ink pad on my Epson Discproducer PP-100
The most easy way to reset Epson PP-100 Waste Ink Pads is to use WIC Reset Utility and reset waste ink counters by Yourself.
There is video tutorial on Youtube - How to reset Epson PP-100 Waste Ink Pads Counters:
Jul 03, 2014 | Epson Office Equipment & Supplies
Epson workforce 1100 printer's ink pads are at the end of their service life
please clean ink pads place and re install in pads and solve the problem
May 07, 2012 | Epson Printer
Parts inside your printer are near the end of their service life.
Most likely the waste ink counter has reached its programmed limit. You can replace or clean the waste ink pads. You need to disassemble the printer from the top; the waste ink pads absorb the ink during cleaning cycles and when you do edge-to-edge printing. Have plenty of newspaper or other material to keep the excess ink from spreading. Remove the pads, blot off most of the ink and then hold them under running water until it stays clear. Blot the excess ink from the area where the pads rest as well. Dry the pads (you can use a hair dryer to speed up the process). Then reassemble the printer. If you want to replace the pads, contact Epson Service.
Fill out the form here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp?cookies=no&com.broadvision.session.new=Yes and get the Ink Pad Reset utility. You will need to provide your printer's serial number. Run the reset program (Windows computer).
Please note that the programmed timing on the waste ink is based on the expected life of the printer. You may have additional failures with the printer in the near future.
I hope this helps.
Sep 29, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson RX600 service required. How can i reset the printer and get rid of the error message?
I just had this same error message pop up on my RX600 yesterday. There is a utility that you can d/l from the Epson website to reset the counter at the link below.
The reason the service message pops up is that it is telling you that the waste ink pads are near the end of their service life and probably saturated with ink. You should still clean the waste ink pads or ink will eventually run out the bottom of your printer and create a big mess. If you do a Google search for something like "rx600 waste ink pads" there are some how-to discussions on doing this yourself. I'm going to clean mine later today.
They say it's not hard to do and you don't have to disassemble your printer, just use a toothpick or modified paperclip to remove the pads after you park the cartridges in their "replace ink cartridge" position and unplug the printer. A more detailed procedure can be found with the Google search.
Aug 25, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Iwant to clean out or change waste ink pad on epson r265 printer. have just used cotten buds to soak up waste ink to fix flashing lights. but i think only a temp. solution
Photo walk through here shows how to access waste pads
http://www.inkrepublic.com/KnowledgeBase/R260WasteInk.asp?C=0
Also shows how to replace with a bottle to collect waste ink
Feb 08, 2010 | Epson Stylus R265 InkJet Photo Printer
Dirty Waste Ink Pads (Epson Stylus R285)
Remove to top cover and replace the ink pad with a new one. You can get these pads from a place called pudsey computers www.pudseycomputers.co.uk
Nov 17, 2009 | Epson Office Equipment & Supplies
Epson stylus c45
most problem with printers are dirt inside. if you want to experiment, try opening the printer, usually held by snaps, if accomplished clean all contacts, cables ribbon wires, then reassemble. thats easier said than done.
Jul 07, 2009 | Epson Stylus C46 InkJet Printer
It is telling maintenance call
This is a standard error which indicates your waste ink pads in the base of the printer are full and need replacing.
I don't have anything specific for the C20UX but it is possible to reset the waste ink counter for that model using the SSC utility .
In terms of replacing, cleaning out or redirecting the waste ink flow your best bet is to get this:
Service Manual (C20 is same as C40 in many respects)
.. and either disassemble the printer to get at the pads [section 4.2.3 in that manual] (you'll need a washable work are and latex/rubber gloves) or to figure out how to redirect the waste ink flow from the cleaning pump into an external tank.
None of this is particularly easy so you may want to consider dumping it and getting a new printer..
Hope that helps.
Feb 22, 2009 | Epson Stylus C20UX InkJet Printer
EPSON STYLUS C43SX PRINTER
You need to reset the waste tank or the counter to resolve the problem.
If your C42 blinks both lights and displays a message to the effect that parts inside your printer have reached the end of their servicable life, then you probably need to clean the waste ink pads. These pads collect waste ink whenever the printer cleans it's heads. The printer counts how much ink it thinks is in the waste ink pads and refuses to print when they are full.
To verify whether this is the case, download the "SSC Service Utility" from http://www.ssclg.com/epsone.shtml.
http://www.ianwillis.co.uk/c42/
Mar 26, 2008 | Epson Stylus C43SX InkJet Printer
EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Mar 25, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus Photo RX700 All-In-One InkJet Printer Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
