Sony stereo amp ta-v7 left channel not working, cd, aux, tuner, o.k. phono
  • 4 Answers
Power Off, Open Top, Remove two screws around heatsink, two lugs and two connectors, remove poweramp board and disconnect from supply board. You will see a relay (black box) on the underside, (this is not the relay that you see as sson as you remove the cover, it is hidden) make a **** in each side and insert flat screwdriver to ease top off. Clean relay contacts with emery paper and switch clean.
Posted on Dec 11, 2011
Turntable with built-in preamp won't play on phono channel on technics sadx950, but fine on CD channel. Is phono channel dead?
A turntable with a built-in preamp should not be connected to the phono input, because the preamp of the receiver or ampifier will be overdriven. The task of a preamp is to amplify the very low level of magnetic cartriges to the high level needed to work a line input and does some equalizing work to the signal. You can check if your turntable has a switch to disable the built in preamp (mostly they are low-end quality), otherwise connect the turntable to a high level input like "Tape", "AUX", "TUNER", "MONITOR", or "CD".
Nov 13, 2015 | Technics Audio Players & Recorders
Will a ipod player play in my sony TA-AX301 AMPLIFIER-No sound
You need a 3.5mm to stereo phono/RCA cable
Plug the red and white ends in to any of the following sockets that are free - Tuner, Tape In, CD, Aux, Video In. They all do the same job. The names are just suggestions, they're not mandatory.
Plug the headphone jack plug in to the MP3 player's headphone socket. Turn the volume up on the MP3 player to about half way. Then select the source input on the amp that matches where you plugged the cable.
That's it. Hope this helps..
Sep 16, 2014 | Audio Players & Recorders
Can i get my ipod player to play in my sony TA-AX301 AMPLIFIER-No sound
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
Need connecting wiring for sony am/fm jx 285 connecting to the sony stereo amp ta-ax 285
If you are trying to connect a ribbon cable tuner to a conventional RCA input terminal amplifier, it won't work because the ribbon cable carries the signal output as well as the data for frequency synthesis which is determined by the processor located in the amplifier ( that is supposed to work with that type of tuner), and the data buss for the buttons on the front of the tuner.
For the time and effort to put into a workaround, it is cheaper by far to get a tuner that will work with your amp. If cosmetics are not an issue, brand of tuner will not matter as their outputs are "Line Level" or nominally 1 volt peak to peak..
Oct 27, 2012 | Sony TA-FE370 2-Channel Amplifier
Hello i need help please..... I have a Technics SU-Z550 and SH-8055 Graphic Equalizer My amp has lost power... lots.! its working one channel louder than the other but the one which is louder still has...
If the same channel is dead on the EQ as is dead on the amp there may be a correlation.
Let's break this into its two parts.
1) SU-Z550: You don't say WHAT source(s) you tried to use on the CD/AUX, TUner and PHONO inputs. The external device itself could be the source of the low volume. Try swapping the Left and Right cables to see if it follows the source channel or stays with the amplifier channel.
Check the controls on the amp to make sure you understand each one's effect on the sound.
"PHONO" is literal and exclusively FOR A TURNTABLE - NOTHING ELSE - EVER.
2) SH-8055: Equalizers don't 'boost' sound, they modify its levels at various frequencies. To do that they should be connected into a Tape loop on your amp. OUTs go to IN's. Then you select the Tape Loop on the amp and that inserts the EQ into the signal path of whatever source you're listening to. It's actions are BEFORE any other amplifier controls such as volume, tone and balance. The EQ itself also has a Tape Loop to replace the one it occupies. Make sure it is not enabled unless you have a Tape Deck on it to use. Choose "SOURCE". The blue LED display is to show you frequencies are present in the program material.
Set all of its lighted band controls at midpoint prior to declaring it defective. EQ is like any spice - a little is good, a lot ruins the recipe.
Mar 21, 2011 | Technics Audio Players & Recorders
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Aug 30, 2008 | Audio Players & Recorders
Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
269 people viewed this question
 Grubhead
Grubhead
