Question about Polycom SoundPoint IP 500 IP Phone
Asterisk 1.2 w/ polycom 500
Hi I'm a bit new at this environment goes.
I have the above setup and I am trying to set the time and date on my phones. I had a few in the office just blinking and after I performed a reboot (in order to update the phone directory) of the asterisk server last night, they all are blinking the time and date. Everything I read pointed me to either a reboot or the ntp.confg file. I checked the file and all subsaquent files and figured what could ti hurt??? While it's not painful but it isn't pretty either. Any help you could give me would be appreciated.
On Polycom 335 how do I reset voicemail for new employee
"If you need to remove the resource files from a phone at some later date-for example, you are giving the phone to a new user-instructions on how to put the phone into the factory default state can be found in 'Quick Tip 18298: Resetting and Rebooting SoundPoint IP, SoundStation IP, and Polycom VVX 1500 Phones' at "
Oct 06, 2014 | Polycom SoundPoint IP 320 SIP IP Phone
Polcom phones stop ringing
go to this website and go to customer support
Jun 24, 2008 | Polycom SoundPoint IP 501 IP Phone
I have a corded model #77519 phone, how do I change the time and date.
The complete user's manual for your phone is available at the following link:
Just use your mouse to click on the link which is the highlighted and underlined text above. This will open a new browser page for you automatically and allow you to download the manual.
Here is an excerp from that manual which describes how to set the time and date:
Caller ID Initial Setup:
After the battery installation and telephone line connection the display will show the Set Language screen:
Set Language
1. Press the Review UP or DOWN button to select the desired language.
2. Once the desired language is selected , press the ERASE button to
confirm selection.
3. Then the display will change to the Set Time / Date screen and the hour icon will be blinking.
Set Time/Date
1. Press the UP or DOWN button to set the current hour.
2. Press the ERASE button to shift to the minute setting.
3. Repeat steps 1 and 2 above to set MINUTE, MONTH and DATE.
4. Once the correct TIME/DATE is shown on the display, press the
ERASE button to end the setting. Then the display will change to
show the normal status.
Changing The Language Mode and TIME/DATE
1. Press and hold the ERASE button then press UP button.
2. Then follow the steps described above.
Good luck, I hope this was helpful.
Aug 12, 2011 | Northwestern Bell 77519 Corded Phone...
I have polycom SoindPoint 301 and i would like to use as SIP to one of the VoIP providers. I dont have asterisk in my network and i would like to connect it directly to the VoIP provider. So there is no...
1st. Get the IP address of the phone. and type that into browser.
*- default user: Polycom / password: 456
*- Under menu SIP, type in your voip provider
*-Under menu LINES type in user info and "secret" should be your password.
Make sure your ports are open (SIP is usually 5060) you can change it in that same config screen.
Mar 28, 2011 | Polycom SOUNDPOINT IP 301 SIP
Hi, Does polycom IP sets support "LIFE DIAL PAD " function ?
Sorry to say but polycom IP sets does not support LIFE DIAL PAD. You can check that on the user manual if you have it with you.
Mar 23, 2010 | Computers & Internet
How do i set the time and date
Note If you press Start Fax Color but the sender sent the fax in black and
white, the HP all-in-one prints the fax in black and white.
Set the date and time
You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
All The Best: Pineworks
Jan 28, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Polycom soundstation 2W
I went to Admn Setup to reboot the system from Please Wait.... & it doesn't work!! Best Solution posted on Sep 19, 2008 2%20stars.png
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Just had this problem with the 'please wait' - go into the admin setup and select Reboot Phone - it then works!
Jun 23, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Faulty time settings p5rd1 vm
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
Open Questions:
Polycom SoundPoint IP 500 IP Phone Logo
94 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Darren  Means
Darren Means
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
