Question about Goldstar MV-1526 Microwave Oven
Emerson Model MW8627W does not heat after changing fuse!
This Sunday, I heard a "pop" from my microwave. I knew instinctively that it was the fuse. The bad fuse was indeed burnt out (brown burn spots on it). So I changed out the bad fuse and replaced it with the correct fuse. The microwave runs fine, but it does not heat anything up. What do you think happened? Nothing looked frayed inside nor there was any burning smells emitting from the oven when I heard the "pop" sound. HELP! I have a goldstar microwave that is set over my stove. I heard a pop when I turned on the microwave so I then turned it off. I looked inside to make sure nothing was wrong. I then truned the microwave back on. The lights turn on the table inside turns but it is not heating anything up. I was thinking it was a fuse, but I am not sure where the fuse is located. Will I have to take the whole microwave down to replace it? Can you help me?
  • Anonymous Nov 03, 2008
    power is on. but its not heating up
  • 2,712 Answers
Please go through this link for possible troubleshooting steps:
Hope that helps!
Posted on Oct 03, 2008
2 Suggested Answers
  • 67 Answers
SOURCE: Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Posted on Sep 19, 2007
My emerson mw8115ss is working but not heating up how do i change fuse
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Oct 10, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Doesn't heat. Power works - evertyhing else
there is a fuse inside the microwave...power, clock will work but it will not heat when it blows
Nov 03, 2009 | Sharp R-510HW Microwave Oven
Went to turn on the mic and heard a pop and now no power. think i blew a fuse. changed it and same thing all over again. any ideas???
I had the same thing to happen to our microwave oven. I went and replaced the fuse in it. Power came back on. Then I tried to pop some popcorn in it. 30 seconds after it started, it made a vibrating noise and shut off. It took the fuse but not the curcuit breaker. The microwave is 14 years old. I have just come to the conclusion that there is buildup all inside the motor parts and that it needs to be replaced. The instruction manuel mentions to replace the monitor switch when replacing the fuse. Since I lost the manuel a long time ago, I asked at Lowes and noone knew what that was....I since found out that it was a safety device installed on the microwave oven so that if the door was not shut completely or was out of alignment, it would throw the fuse. Anyway, I am happy with the service we got with this microwave. It has been through several slammed doors and lots of use. We have been very satisfied with our Frigidare Microwave. It has held up well.
Oct 15, 2009 | Frigidaire FMT118E1B Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Emerson MW9111 will not heat- all timers & clock work
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Sep 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Emerson Microwave (mw8992rd) not heating up
I have replaced the main fuse on this model. Though blown main fuses are common in this model, it will not even turn on when they blow, so your problem is most likely NOT a blown fuse. I had heard of your problem so, when replacing the main fuse inside one, I looked for additional fuses and saw none. The store was wrong. Even if it were a fuse, the security Torx screws mean that you couldn't replace the fuse anyway.
This microwave seems to have been haphazarly been recommended by Consumer Reports, but it is terribly unreliable. The turntables break when popping popcorn, the main fuse repeatedly blows, and they also stop heating.
Oct 19, 2008 | Emerson MW8985W Microwave Oven
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Emerson 600 watt microwave
disassemble it and look for disconnections to control panel from faulty factory assembly
May 30, 2007 | Emerson MW8627W Microwave Oven
How do I set the power level?
On our site, we have three different older Emerson microwave manuals you can download free: MW8103SS MW8104SS MW8627W If none of these is close enough to help you, you can e-mail us a photo of your control panel and we should be able to give you some operating tips. You can e-mail us through our site, which is linked at our listing here on FixYa:
Feb 28, 2007 | Emerson MW8168B Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
181 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
