Question about Whirlpool Duet GHW9150P Front Load Washer
Diagnostic complete I did the diagnostic on my washer and now the code C:03 is on the display, what now?
  • judysala Oct 04, 2008
    Apparently when I saw that the washe was just making noise while it was running diagnostics, I thought it was messing up again so I unplugged it but then I plugged it back in and reran diagnostics. That's when I got the code. I since then washed 7 loads without ANY problems until my last load again, (the only load I am using only hot water) Thanks very much for this website cured my initial problem either way (F 06). My washer went back to it's bad self, I guess I'm going to half to call an expert.
    Thank you gentlemen, saved me from going to the washeteria today!
    I looked up the Hot Water Inlet Valve, apparently it's only going to cost me about $20. I turned my cycle to rinse and spin with cold water selected and it just finished a few minutes ago with no problem. I unplugged the washer and I'll run the diagnostics on it again tomorrow. I did some troubleshooting on it today myself. I checked every connector, plugged and unplugged all the hoses and you name it. Mind you I'm just a data analyzer but all as well, everything seemed in place to me. Thanks so much for your feedback, when I called the Whirlpool 800 number they would not give me a couple of minutes to troubleshoot or gave me the details of my potential problem as this website has. That was Whirlpool, great product, not so great warranties.
    Thanks again
  • 5,911 Answers
Your washer apparently did not complete diagnostics. The display indicates that it stopped at the segment of the test where it was attempting to fill by using the hot water solenoid. The diagnostic test segments check the following:
C:00 - Door Lock
C:01 - Flow Meter, Cold Water Solenoid
C:02 - Dispenser Motor, Dispenser Contacts
C:03 - Hot Water Inlet Valve
C:04 - Motor rotates CW at wash speed
C:05 - Heater & NTC (Heater Sensor)
C:06 - Drain Pump
C:07 - Motor rotates CCW at 35 to 90 rpm within 15 seconds
C:08 - Motor rotates CCW at max. speed.
If there is an error associated with any portion of the diagnostics, the washer will shut down, an audible alarm will be heard, and an error (F) code will be displayed. Sometimes the washer will experience momentray glitches during testing, however. I would recommend unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). The is the main "brain" of the washer. Upon reset, attempt diagnostics again and let me know the results. I hope this helps you.
Posted on Oct 04, 2008
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell Oct 04, 2008
    "F06" is a Motor Speed error. The following link explains:
    http://www.fixya.com/support/r714929-f06...
    This could be an indication of a Drive Motor failure and/or Motor Control Unit (MCU) failure. It could also be something as simple as a loose connector or broken wire between the Drive Motor, MCU, or Central Control Unit (CCU). Read through the link for detailed information about this. I would start by verifying all your wiring connections. Then, rule out the motor by doing resistance checks on the motor windings. In most cases, this error is generated by a failed MCU.
    If you you are somewhat savvy with electronics, this repair can easily be accomplished by the average do-it-yourselfer. Replacement parts can also be ordered on line and shipped directly to you. If you wish to save yourself from a service call, and avoid labor charges, I may be able to assist you further. Just let me know...
  • Jeff Rockwell
    Were there any other error codes displayed? What occurs when you attempt to use a HOT water only selection?
  • Jeff Rockwell
    Well...keep me in mind,and let me know if you have any additional problems or error codes. I'm familiar with this washer as I've worked on it many times. I also own one. I believe in the DIY aspect of fixing most common problems as I have seen the business side of the appliance repair business and didn't have a good feeling about the things I had to charge customers for. Many of these repairs are simple with a little guidance. Just some food for thought...
F code on a cabrio wtw6400sw3 sounds like a bearing is going out
its not an f code its an f code then u have to add the applICABLE NUMBER THAT APPLIES.
SEE THE LINK Whirlpool Cabrio Automatic Diagnostic Mode
Here are instructions for entering the technical diagnostic mode. This mode is designed for service technicians familiar with the product testing operation, if you need more instructions, you can find information on the tech sheet located inside the console of the washer as the entire diagnostic process cannot be published on this site. Always disconnect power supply before entering any closed section of the appliance and wear safety glasses and gloves.
1.Be sure the washer is in standby mode (plugged in with all indicators off)
2.Perform the following sequence of movement using the cycle selector knob.
3.NOTE: AFTER RESET, sequence must be completed within 6 seconds.
4.RESET - Rotate cycle selector knob counterclockwise one or more clicks to clear sequence.
5.a. Rotate cycle selector knob clockwise one click and wait ½ second.
6.b. Rotate cycle selector knob clockwise one click.
7.? Successful activation of Diagnostic test modes will be indicated by all status LEDs (except for Lid Locked) flashing ON and OFF in half-second intervals.
8.NOTE: LED names may vary between makes and models.
9.If the status LEDs do not display as described above, the sequence may not have been completed within 6 seconds. Repeat step 2 to ensure this was not the cause Whirlpool Diagnostic Mode
Dec 31, 2016 | Washing Machines
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
How to run a diagnostic for washer model MHWE450WW01 Maytag
Starting Error History Software Version and
Diagnostic Test:
NOTE: Washer must be empty and the control must be in the
OFF state.
1. Close the door.
2. Select any one key (except "STOP/CANCEL" and "CONTROL
LOCK" and follow the steps below using the same key:
Press/hold for 2-5 seconds, Release for 2-5 sec, Press/hold for 2-5 sec, Release for 2-5sec, Press/hold for 2-5 sec
3. Upon release, all yellow/green console LED lights will turn ON
for 5 sec.
4. If there are any failure codes stored by the washer, the display
shows them.
Note: The last four errors will be displayed.
5. Press the same key to advance to the next code.
6. After the indication of error codes, the UI, CCU, and MCU SW
version will be displayed.
7. The number of cycles since last clean washer cycle is displayed.
8. All green console LED lights will turn ON for 5 seconds.
9. Next the washer begins the automated diagnostic test.
10.To cancel out of service mode, press the "STOP" button.
Apr 10, 2014 | Maytag Washing Machines
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
1995 Jeep Wrangler 4.0L.. It has OBD 1... check engine light is not on but there is a code stored in the ECU aquired by 3 key turns... The code is 55... What is this?
55 Completion of diagnostic code display
It just says that it completed the diagnostic check (get one everytime you start your vehicle)
Jun 03, 2011 | 1995 Jeep Wrangler
My cabrio wtw6200sw2 has F50 code and won't spin I can't seem to find out what the code means. Could it be the motor coupler or controller board?
The F50 code for the Whirlpool Cabrio is most commonly a Motor Control Board failure.
Motor Stalled
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
? Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
? If basket turns freely, see TEST #3, page 4 of the Diagnostics and Repair manual.
The Diagnostics and Repair manual can be downloaded as a PDF document file here:
http://www.mediafire.com/?np4yufblj33c0xm
DIAGNOSTIC TESTS
There are three diagnostic test modes available: Automatic, Manual and Console. These tests allow the factory or service personnel to test and verify all inputs to the machine/motor control. You may want to allow the automatic test cycle to complete prior to going into specific troubleshooting tests.
ACTIVATION OF AUTOMATIC DIAGNOSTIC TEST MODE
  1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on).
  2. Select any one button (except POWER, START, STOP and PAUSE/CANCEL) and follow the steps below, using the same button (remember the button):
  • Press/hold 3 seconds.
  • Release for 3 seconds.
  • If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
  • If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause.
  • If still unsuccessful, see Diagnostic: Unsuccessful Entry.
  1. The program then checks for saved fault codes:
? If there are no saved fault codes, all indicators on the console will momentarily turn off, then
turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
DIAGNOSTIC: Automatic
Performs a five-minute automatic test with water functions to check major washer functions (door can be open). Press the same button used in step 2 above to advance through automatic test steps.
NOTE: Basket must be floating in order to agitate.
Feb 01, 2011 | Whirlpool WTW6400SW Cabrio Washer
I can not get it into service mode.
There is not a "diagnostic mode" for the neptune washer.
All tests and functionality are done at each setting using the timer (except the tach circuit)
What is the problem you are looking to diagnose??
Thanks!
Mar 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
MY TROUBLE LIGHT IS STAYING ON
2000-2004
The Diagnostic Mode is entered by turning the ignition from OFF to ON while holding the reset switch in. The normal power-up sequence will occur before entering the diagnostic mode. Diagnostic codes set during this power-up sequence will be stored as well.
Important Note: Be sure no diagnostic codes are indicated before reset is held in for more than 5 seconds or diagnostic information will be lost.
When in diagnostic mode the odometer will display the first diagnostic code. When the trip switch is pressed again the next code will be shown. If the trip switch is pressed for more than 5 seconds at any time while in the diagnostic mode, the diagnostic code displayed will be erased.
There are 7 different diagnostic codes available. They are as follows:
d01 - Speed sensor power output shorted low
d02 - Speed sensor power output shorted high or open
d03 - Not Used
d04 - Not Used
d05 - Speed sensor return shorted high
d06 - Speed sensor return shorted low
d07 - Not Used
d08 - Speedometer power over voltage
d09 - Speed output shorted high
d10 - Speed output shorted low or open
CAL XX - Speedometer application calibration number:
14 = Domestic
15 = HDI
When in the diagnostic mode, all codes are displayed in sequence from d01 to d10.
As a code appears in the display (for instance d02), it will read "d02Set" if set or "d02CLr" if clear.
The diagnostic mode is exited either by turning ignition from ON to OFF to ON again without depressing the reset switch or if a speed signal greater than 5 MPH is detected.
Diagnostics cannot be performed if system voltage is less than 9 VDC or greater than 16 VDC. The only exception is d08 which is set when system voltage is greater than 16 VDC.
After all the diagnostic codes are displayed, the speedometer calibration number is displayed (CAL 14 for example).
Jun 12, 2009 | 2000 Harley Davidson FLTR-FLTRI Road Glide
Whirlpool Duet GHW9150P Front Load Washer Logo
401 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
