Question about Kitchen Ranges
Internal cooker hood
I live in a flat with no chimney and i would like to install a cooker hood. how do i do this please.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi judav,
I'm Harvey the Master Plumber.
Your problem is: You live in a flat with no chimney and you would like to install a cooker hood. how do you do this please?
Is there living space above? If so you can't go straight up. If your range is on an outside wall, it can be piped out the back. If only attic or roof above, no problem. Just pipe it straight up useing B-vent pipe or equivlent. If you can't do any of this just get a hood that vents filtered air back into the room.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 14, 2008
Fl3 code. heater working fine when i closed last year. will not start this year. showing fl 3- does not ignite , does not do anything ..help please
3.
Spillage at A.Cold chimney A.Allow heater to operate 5 minutes to create draft action.
draft hood B. Vent pipe pitches down to chimney B. Reinstall vent pipe to pitch up from heater to chimney.
C. Blocked chimney C. Remove blockage.
D. Draft hood altered D. Install factory-provided draft hood.
E. Prefabricated chimney with incorrect cap E. Install a Nationally Recognized Testing Lab (NRTL) listed vent
http://www.jandy-downloads.com/pdfs/Lite2_LJ_IO_H0248900F.pdf
I tried to copy the FL3 write up from the chart but it screwed it up a little. Look at Page 35 of the manual for a clear copy
Jun 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
We have a intergrated cooker hood in a 600 opening and want to change to a chimney type,have been told you need to leave a gap each side is this right and for what reason please many thanks
Depends where you live, an EU law came in force a few years back stating that you had to leave a 50mm gap either side of a chimney hood for heat reasons, coming from the hob to the underside of the wall cabinets. But i am pretty sure that this is for newly fitted kitchens only as you would find it hard to purchase a 500mm hood. Hope this helps.
Jan 02, 2010 | Kitchen Ranges
Designair 60cm chimney hood chk60ss what gap between cooker and hood ?
If gas cooker you have to get specs.....We usually get the chef of the house to stand in front...Head banging will be a call back we hate...
Oct 27, 2009 | Kitchen Ranges
The wiring from the fan on my cooker hood has no earth is this ok
yes mam earthing is must and should be provided because of safety for the equipment and the operator,
Oct 06, 2009 | GE Monogram ZV1050SFSS 42" Island Chimney...
No instructions nor fixings with cooker hood. How do we attatch it? How do we get hold of fixings as staff at wicks were useless. Cookerhood EFC90950X zanussi
you will have to place a straight edge on the top on the hood near the exhaust pipe then mesure from the floor to the bottom of the straight edge, that will give you depth then here is the demisons you have to build the box in. And if you don't have the power there you need to get a contrator or do it yourselfer to install it four you.
Price Range:£342 — £2,084 Average Price:£673 —— Colour body Stainless Steel. Body Material Stainless Steel. Colour chimney Stainless Steel. Typology Built-In. Motor location Integrated Motor. Operating Mode Convertible. Connection Rating (W) 225. Voltage (V) 230. Frequency (Hz) 50. Approval certificates IMQ. Length electrical supply cord (cm) 190. Height of the chimney (mm) 815/1970. Height of product, without chimney (mm) 815. Dimensions of the product, with chimney (if exists) (mm) 815-1970X898X490. Dimensions of the packed product...
Aug 21, 2009 | Electrolux Kitchen Ranges
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Kitchen Ranges Logo
601 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
