Question about Sony DAV-S500 System
Power problem - total power failure
Hi all, my system has just died , was working fine, movie flickered a couple of times then the whole system just stopped !, no power anywhere, checked powerboard fuse and its fine, so stumped now , suspect i need replacement power pwb part number 1- 682-284-42 ( i think) but i can't find a replacement anywhere ..
can anyone help ?
  • 3 more comments
  • tk29MarkS Oct 04, 2008
    yes it is the DAV-S500 .............
    and any help would be appriciated seem's like the whole board is dead , power comes in and the on / off switch works fine, plus power goes through the fuse located on the back of the board, but after that it all seem's dead.. no display, can't eject DVD ...
  • ditsy76 Oct 19, 2008
    I have the same problem, just got back from holiday switched on my Sony DAV-S550 and it is dead. Standby light is on but nothing else. Can anyone help? Many thanks
  • jude35 Nov 03, 2008
    total dead. internal fuse ok and switch working just nothing else
  • Anonymous Dec 16, 2008
    Same problem, lights are on but nobody home.   Anywone?
  • mariavii Dec 23, 2008
    Same here. Unhooked system for room renovation and when i rehooked it all up, the red light on the power button is on, but system is dead.
  • 10,594 Answers
You need to make sure that power supply has fried. It requires to check output voltage by volt meter.
What is the exact model number of your Sony home theater system to guide you properly. Is it DAV-S500 or some thing else.
Posted on Oct 03, 2008
Hi I have a horizon t4000 premier treadmill, everything seems to work fine when I plug it in, it all the console displays fine, but p1 (programme 1) just keeps flashing and no response from any of the
Hi Anthony, sounds like there is a bad connection from upper to lower, a pinched or bad cable, or bad solder on a connection point.
With the "flickering" of the console lights mentioned, this tells me that the power supply connections to the console were suspect at one time, and doing nothing and having it "work ok now" is not a good sign of something being fixed. Also, with the flickering, this would mean the upper board would be intermittently powering up / down, causing massive trouble with the onboard CPU which is trying to operate the system. I would advise against using the unit the way it is, and have the control board checked. You can contact jatinah electronics for further help if needed. Good Luck!
Jan 11, 2015 | Horizon T4000 Premier Folding Treadmill
Hp s3644uk wont boot
if you had lightening activity in your neighborhood, and the system was plugged into a wall socket, it may have suffered a power failure and thus, the power supply has been affected by current surge. If the PC system is one year or less, refer to contacting HP techsupport for support : you will have to replace the power supply
Nov 14, 2012 | Computers & Internet
Dell xps m1710 no power, no codes flash.
If you were getting the error message that the computer was overheating, you were lucky that it kept on going still . I would suggest to get the chassis fan replaced and then check.Most likely the chassis fan has died leading to the computer not starting .The extended overheating might even have caused a motherboard failure. As the AC adapter and power button light flickers
Thanks for using Fixya
proton
Apr 26, 2010 | Computers & Internet
Jvc projection will not work
May be a fan failure. Mine did the same thing a couple of times. i unplugged the tv, cleaned the cooling fan and plugged back in..the tv worked fine after that.
Apr 20, 2010 | JVC TS-CL110UAA Projector Lamp
Totally seized up
the power supply of your dvd player is deffective,try to change the filter capacitor or the small capacitor of your power supply board.(kira_ryuk99@yahoo.com)
Mar 10, 2010 | Televison & Video
Flickering in half screen after 1 to 2 hours
Probably caused by a power supply nearing its death.
Try to verify this by placing a portable fan to the side of the set with airflow directed at the vented sides.
If this lengthens the operating time, there is a good chance that some minor components in the main supply have developed low values of capacitance and higher losses which worsen with warmth.
Listen closely at the vents with the sound turned down to attempt to detect a squealing sound while the TV is in its failure mode; if you find this, it is also a sign of power supply trying to die.
A tech equipped with a capacitance meter that measures losses at the same time, could find and replace the weakened parts without a whole lot of labor and little cost for parts.
Nov 26, 2009 | Philips Televison & Video
Computer monitor problem
power supply is most likely going could be capacitors on the vga /inverter board also needs to be checkd out at a service location
May 01, 2008 | Gateway FPD2275W LCD Monitor
Power won't stay on, can't get dvd out
One of the motors in the mechanism died making a near short circuit. When the DVD tries to energize the motor, a lot of current passes through the circuits making the PSU protection to shut down the power supply to avoid damage or fire.
To get the movie out, you'll have to disassemble the DVD player and remove the disk. After that the DVD will be unusable because of the failing motor. The replacement often is more expensive than buying a new Chinese DVD player.
Apr 30, 2008 | Kenwood DVR-505 DVD Player
No power to player!?
Open it up and check the main fuse. It is located on the board where the wall plug enters the chassis.
Jan 19, 2008 | Sony DAV-S500 System
Sony DAV-S500 System Logo
275 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
