Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice maker stopped making ice
I have a sie by side whirlpool gold and it just quit making ice. Did all the troubleshooting and still nothing. Help I have Wirlpool ED5PHEXRS00 side-by-side, its ice maker stopper making ice after 2 years since purchase. I replaced the ice maker but it did not help. On a closr look, there is no water coming to the ice maker, even though the water is dispensable from the door. Can the water line to the ice maker be frozon? Or an electric motor issue? And how to troubleshot next?
  • 1,861 Answers
Whirlpool Part Number: 4389177
Inlet valve is probably bad
Posted on Oct 03, 2008
    Master:
  • 479 Answers
Its the problem in the compressor.
so please check all the ventilations something must be blocking the air.
    Genius:
  • 3,422 Answers
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Whirlpool conquest g56sha not making ice
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 27, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
The ice maker is not working (does not make ice)
Aug 30, 2011 | Whirlpool Gold GB2SHTXT (219 cu ft)...
Not making no ice.
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
It just stopped making ice yesterday. A question.
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
Sep 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
293 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
