Question about Acer TravelMate 2300 Notebook
I can't fd my e drive
I lost my e drive.
It's the ne I put my cd's in and I can burn them or read them. i will put a disc in and it will not get read.
  • Jaipal Reddy
    Jaipal Reddy May 11, 2010
    Hi Monika,
    We need the following information to provide you the exact solution:
    1. Operating system.
    2. Check the device status in device manager:
    Click start -> Select Run -> Type devmgmt.msc  -> Click Ok.
    Click on the + sign next to the Sounds, video and game contrlollers and let me know the entries listed there.
    3. If you have the Drive name listeed there check whether it has yelloe marks on it.
    Please get back yo us with the above information.
I put in a disc and no options are coming up on the screen and the disc is not reading burning nor burning cd
Try and access the CD-ROM drive from My Coputer folder. If the CD can be read, that means that auto run is disabled on your system. If still you cann the read the CD, then there is a problem with your CD-ROM drive. Try cleaning the CD-ROM drive lens with the appropriate cleaning kit.
Aug 07, 2010 | Computers & Internet
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Cd burner quit working properly
Just a thought! Check your hard drive is not out of space as it may be having buffering problems..
Feb 19, 2008 | Computers & Internet
CD RW/ DVD RW Drive Will not read and Burned discs or burn to blank discs
I suggest a firmware update from Toshiba. If this does not help then your laser in the drive is no longer capable of this task. Also just thought about it but make sure the media that you are burning to is the same as the drive + or - R's
Jan 22, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Dvd-rom trouble
Hi, first of all, I'd check if you have the problem with CD/DVDs burned (written on a CD/DVD writer) or you have it also with original CD/DVDs, which would be weird. Depending on your finding to the above point I'd do one thing or another, but to me does not look like a driver problem. I'd check with Toshiba support if there's a new firmware for your drive, this does improve the media the device can read and correct problems like the one you mention. To know the fimware version you're using, open device manager and go find your drive, right click on it and choose details tab. Normally the firmware revision is the number at the end of the instance. Good luck mate !
Dec 29, 2006 | Toshiba (SD-M1212-S) DVD Drive
Computers & Internet Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
