Question about GE WCCB1030 Top Load Washer
Timer type Hi after reading some of your previous answers i found that my timer needed replacing. My ge commercial washing machine is model number wccb1030dowc with a invensys timing mechanism. The problem im having is that when searching for a replacement the wccb series has many different numbered timers such as wh12x929 and wh12x933 etc. Im guessing this has to do with the switchs cycles. I cannot find any such number on my timer. Will any one of these work and if not do you know ,what specific invensys timer is in a wccb1030dowc. Thanx!!
  • sevear1 Nov 10, 2008
    Ok this problem has been solved ...thanx anyhow!
    New Friend:
My washer comes on then jumps straight to 1 min left ??? It won't wash or spin what's the problem it's a Siemens washer
Posted on Dec 18, 2013
  • 27 Answers
Give your parts distributer your model and serial number and they can get you the proper timer.
Posted on Mar 26, 2011
Increase volume of the Timer on a GE Gas range
Which model of range do you have?
Ok I found the GE owners manual for this range. http://www.searspartsdirect.com/partsdirect/user-manuals/JGB700SEJ1SS-GE-GAS%20RANGE-manual
I read through it a couple of times and it doesn't mention anything about adjusting the timer volume. However, there is a GE hotline you may call during regular business hours that would probable be the best way of finding out if it can be adjusted. that number is
1-800-626-2005
GE Appliances Answer Center®
Monday–Friday: 8 a.m.–10 p.m. ET
Saturday: 8 a.m.–7 p.m. ET
Sunday: Closed
Sorry I wasn't able to find the specific answer but if this 1 800 number doesn't have the answer nobody does.
Sep 26, 2017 | GE Kitchen Ranges
Can i use a different model a model nunber for a ge washing machine timer model number wssr3120woww
No you can't use a different timer for your machine. Each timer number has different number of cycles and some mount different. Here is the timer number for the model you listed. WH12X10051
Feb 16, 2015 | General Electric Washing Machines
How do I replace a timer on an old GE washer machine, model # WWA8616MALAD ?
Open following link to help identify part:
http://www.repairclinic.com/GE-Washing-Machine-Circuit-Board-Or-Timer-Parts
Each part shows a skill level.
Repair clinic also has toll free number, and live chat.
Possibly they have a troubleshoot that will identify if timer is bad, or another part is cause of problem.
Feb 22, 2011 | Frigidaire FWS833A Top Load Washer
Gets stuck in cycle I have to turn the knob to get it to continue. The machine is the heavy duty large capacity I can't find a model #
Looks like you need a timer. If the model number is really gone there should be a part number n the timer. look everywhere around the door/lid and even on the back. Eric
Aug 12, 2009 | Washing Machines
Need to find an Eaton timer for a GE washing machine ( 20 yrs old) Eaton part number 114-317-20 1/3 rpm, 115 vac. thanks Bob Westerdale PS- not sure of the model number on the washer. label is missing.
What is the GE part number it ? What is exactly the problem with the timer? Is i the AC timer motor or is it the contacts? You may be able to disassemble the timer & repair it.
Ebay is also a source for older parts.
Jun 08, 2009 | GE WDSR2080D Top Load Washer
Please I need the colors and in which number I need to put them back at the timer
If you look on the back of the timer,...if it is an older type timer/dryer which it sounds like it is because most modern timers have plug in type wirering harnesses,...you will see,(you might need magnifying glass), that each point to connect a wire at will have a y, (yellow), g, (green), blu, (for blue), R, (Red), V, (violet) and blk or bk for black and so on and so for stamped on the time next to the spade the wire connects to...write back with a model number if that doesn't help...
May 12, 2009 | GE Washing Machines
It washes but will not spin
After having a similar problem and looking all over this website, I found a lot of answers from "experts" saying that the washer should be replaced, or replace the motor, etc.
I just found this at the GE website, and it cured the problem in less than 2 minutes. I'm no expert, but I'd at least recommend trying this.
http://www.geappliances.com/search/fast/infobase/10013033.htm
Apr 15, 2009 | GE WWSE5200B Top Load Washer
GE WASHER, REPLACED TIMER THEN BIG SMOKE
Be sure you are using the EXACT replacement part. The wiring may be different if it is a "close" match.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Washing Machines
Will not move to the next cycle.
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 07, 2009 | Kenmore 24032\24036 Top Load Washer
    GE WCCB1030 Top Load Washer Logo
    166 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
