Question about New Bright Toys
I have bear family musical train #184k . I need some track
4 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: hi having trouble with
Yes, additional track is available from several places, such as Hobbylinc.com, and TowerHobbies.com. At this time, just after Christmas, they are out of stock, however. Walthers.com has them in stock (1-4-2011). You can find extra track on sale on eBay, as well. Be sure to get the track with the brass covers, as New Bright sells battery powered trains that use bare plastic track, which will not work with the 384. A Google search will turn up more sources.
Posted on Jan 04, 2011
SOURCE: Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
Posted on Jun 01, 2009
ok I have a train the light and sound work, but the train does not move. Used alligator clips from battery direct to motor, then the motor runs. Just ordered a circuit, will post when receive circuit with sound 15.00.
Posted on Jan 22, 2010
Why does the music from my Lionel train musical boxcar sound slow and warped?
Whoah! Wow! Lionel trains! I'd like to see some images if you can take some and post them here. Best guess, blindly guessing, could be corroded metal conducting battery DC power. Could be broken wire conducting voltage. Could be a switch that is stuck. Could be a commuting wire that is out of place. A commuting wire is that which is attached to the train car and touches the track to pick up the DC voltage running through the track. Does that make sense?
Add photos if you like. If you are taking care, and using all your senses, you may determine the cause of the problem for which you are seeking an answer.
Have fun, and -- you are on your own, be careful.
Dec 03, 2016 | Cars & Trucks
Hi having trouble with our new bright musical holiday station electric animated train set...very frustrating as one of the train tracks broke off a little part so no matter what my husband tries to do the...
Dec 12, 2010 | New Bright 384 Holiday Express Animated...
Music will play but train will not move or do any other function
I'm not spending money for asking if there is a button to push to make the train go around the track! That is a simple "yes" or "no" answer! I can promise you that I will not buy another product from your company and will tell all my friends about my experience with your product!
Spaldingsr
Dec 22, 2009 | New Bright Holiday Express Santa's Mailbox...
Locomotive won't come on
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Dec 12, 2009 | New Bright 181 Toy Christmas Train
New Bright Model #183 - how do I make the train go? The light works when the engine switch is in forward and reverse, but the train doesn't move (wheels do not turn). The music plays from the coal are -...
Nov 27, 2009 | New Bright 181 Toy Christmas Train
Hi
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
I bought a new brighton toy christmas train set at a garage sale. the jert told me it worked. the music will play and the engine head light comes on but the engine will not run. are there replacement...
If says 187 on the box, check out this solution:
May 17, 2009 | New Bright 181 Toy Christmas Train
An electricalroblem with Holiday Express train
Mar 31, 2009 | New Bright 181 Toy Christmas Train
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Dec 16, 2008 | Peg Perego Vespa Scooter
Peg Perego Thomas the Train Ride-on Music button not working
It could be a bad switch or the music board has a bad contact.
Nov 21, 2008 | Peg Perego Vespa Scooter
Toys Logo
123 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
