Question about Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
Broken refrigerator door handle
My refrigerator door handle broke when I routinely opened it recently.  My technician insisted, before seeing it, that there would be screws at the base of the door that would need replacing.  However, when I looked more closely I realized that the problem is that the metal at the base of the handle sheered right off.  This seems like a very unusual case of metal fatigue!  My frig is less than 3 years old but not covered by warranty any longer.  I really liked it before this problem.  What can I do?  I don't want to pay a technician to look at it, only to tell me it can't be fixed or I need a new door.   I even took photos because I'd never seen anything like this before.  The top of the handle is fine but there's nothing to support it at the base.
  • 1 more comment
  • bCos Dec 04, 2008
    I have exactly the same problem. 2.5 year old F&P E442BRMFD 'Iridium' and the bottom of the handle separated from the door. The metal 'boss' which attaches the handle had sheared in half.
    I found this reference which implies a known design fault which they have since corrected. Unfortunately the PDF describing the issue is a 'paid' feature of the site.
  • 5bags Mar 07, 2009
    I just had the same thing happen today (03/07/09). The fridge door seemed to seal way too tight, resulting in having to pull hard on the door to open. How do I fix this????
  • betsyf Apr 13, 2009
    we just had the same problem. The handle came off in my hand - 2 years old, and otherwise great 'fridge. Looking for a solution!
5 Suggested Answers
  • 8 Answers
SOURCE: refrigerator
the compressor might have had it
Posted on Dec 20, 2007
SOURCE: Fisher & Paykel Model #E522BRX Fridge portion not working but Freezer OK
I bought this nice looking fridge 4 years ago and after 18 months the fridge part was warm and all the food had to be thrown away. The freezer part was still working.
I called the store that I bought it from and they told me to call a recommended service company. When I called they said that there was a common problem with the fan breaking down. (The fan is what makes the fridge cool as it blows the cold air from the freezer up to the fridge).
They did not have the part in stock and said it would take 6 weeks to order it from New Zealand!!!
I called the store back and had made a commotion so they replaced the fridge with a new one.
Now after two and a half years the same thing has happened again. I called the store and asked if this was a design flaw and did they have a recall on them, but the person I spoke to claimed that they have sold very many of these models and no one else has the same problem.
I am 65 years old and have had quite few refridgerators and none of them has ever broken down at all. I believe that the same problem of the fan breaking again is a design flaw and should be fixed by the manufacturer.
It seems like many other people have the same costly repair problem with these models. I would never buy Fisher & Paykal again!!!
Posted on Jun 11, 2009
SOURCE: handle pin broke
this happened to mine while still under warranty, eventually the repair man brought a small replacement part which took 5 minutes to fix, but not before a previous engineer had ordered a complete new door. you should be able to get the part ordered, and it would be easy to replace yourself. Now my FP oven has broken down again
Posted on Jan 26, 2010
  • 132 Answers
SOURCE: Every time the top frig
There is an air duct that connects the fridge to the freezer. When the opposite door is closed air is trapped and forced out the other door pushing it open.
The door seals contain a magnetic strip that hold the door to the fridge, these magnetic strips have lost their strength, to test this use a shhet of paper. Open the door, place the sheet of paper across where the door closes, shut the door, then slide the paper out. If the paper comes out without any resistance then the door seal needs to be replaced.
Posted on Apr 01, 2011
How do i replace offside rear door handle
You would need to take the pannel off to get to the internal part of the mechanism. Something has broken or come apart in the opening mechanism. I'd let it go if considering replacing.
Mar 05, 2015 | Citroen Berlingo Cars & Trucks
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
How do i fix broke handle on bottom sliding freezer door
Have you surfed the maytag website for parts,you might have a few options and pick up the exact handle you need for cheap.Good luck
May 02, 2012 | Refrigerators
Driver side door wont open from outside
Fortunately, it means that the mechanicals of the door opening device are working right, if you can open from the inside. The rigid wire that connects the outside handle to the door opening mechanism became loose, or a plastic connector broke. Disassemble the door panel, reach the handle from the inside, and see if there is a thin rod dangling somewhere, and if not broken, just put it back in place.
Jan 10, 2010 | 2008 Audi Q7
Drivers door won't open from inside vehicle, opens from outside with no problem.
you may have a broken inside handle, open the door, remove screws holding door panel on,then pry door panel off, it has plastic retainers that hold panel on they pry off and pop back when installing panel, once the panel is off you will see if the rod just came off or if handle broke if its the handle replace it remove screww holding it and install new one, some are held with revits, drill revit to remove,use screws to reinstall. hope this helps.
Dec 26, 2009 | 1999 Chevrolet Suburban
Freezer door handle broke off Handle is not broken but the 2 caps item # DA67-01716A and 01717A Are broken
If you can't find the parts on line then find a place with a walk in and take the whole door. Lot's of usefull parts.
Jul 07, 2009 | Refrigerators
1992 Ford Explorer Sport. Outside door handle not
Door handle seems loose and not connected? Then the plastic clip broke inside the door. Take off the door panel, 3 screws, and door lock cap and plastic insert around inside door handle. pry around the bottom first, and go up, when you reach the top, pull up, please be carefull to not break any more plastic. you will see a squarish opening midway up the door toward the latch. reach in and pull a rod toward the opening. You see a broken piece of plastic on the tip? if so take it off and get the replacement part for it at an autoparts store, install the new one and your set. I have broke to many of these so i ended up bending the end of the rod and using a nut to hold it in.:]
Jun 20, 2009 | 1992 Ford Explorer
Rear door handle broke door is closed and i need to open it
other than drilling out the two studs on the handle ,the only way is to remove the inner door panel and open it from inside the door.You can see the actuator once the panel is removed
May 30, 2009 | 1991 GMC Safari
Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
HI,
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Apr 24, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Driverside door handle frame is broken and cannot open the door
check handle is ok or broke
check behind handle shaft if it is came out from- handle point
Mar 21, 2009 | 1991 Honda Accord
Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator Logo
245 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
