Question about Belkin Computers & Internet
I am replacing BT 105 modem with a Belkin adsl2 modem with wireless g router. The 105 has a blue cable with a square connector. I tried to put the yellow supplied cable in the back of my computer but it did not work. Do I need an adapter to get this going??
  • 661 Answers
No, but you need to configure the router to connect to the internet, you should have a "quick start guide" that will help you connect to your router and set your ADSL dial settings (as it needs this to connect you to your internet service)
once these connection settings are set you should be able to connect to the internet
you can then explore the other settings including the wireless configuration of your router
Posted on Oct 03, 2008
I have a comtrend ADSL2+Ethernet Router hooked to my desktop Pc and a G-Wireless Router made by Belkin.According to the tech I should be able to connect these two to use my Laptops, but any way I've tried...
You dont need a Belkin Disk to set up - this can be done manually you can get a manual from this site http://en-us-support.belkin.com/app/product/list/q/routers/ select G in the first dropdown and then your model - theres two to choose from and then then the version
you have a choice - you could change the comtrend router to just use the modem - bridged mode - they have a few different routers see here http://www.comtrend.com/links/i$residential-adsl2-modem-router$product.htm so not sure which one you have if you can bridge to just use the modem then connect tothe Belkin and all PCs should connect to the Belkin
OR you can connect two routers together Leave the comtrend router set as it is -
Set the IP address of belkin router to same subnet as the comtrend. Depending on the DHCP range of the comtrend router - set the IP outside this range - so if comtrend is set to give an ip of 192.168.0.2 to 192.168.0.100 - set the belkin to 192.168.0.254 Disable the DHCP in the belkin.
Connect the comtrend LAN to one of the Belkin LAN ports - you may need to use a crossover cable. On the belkin the WAN port will be left unconnected
Mar 20, 2010 | Belkin (F5D7231-4) Wireless Router
I followed the instruction but can't seem to connect to the internet, do i need a separate modem or is the one in my regular computer enough. i have belkin G wireless router. i have tried everything....
If you are trying to connect wireless you will need a wireless card. Routers are very peticular about the way they are set up. Unhook everything turn everything off and reboot computer, and run the software disc that came with the router. Plug the dsl into the the Blue colored port or Wlan then reboot computer and then plug cable into computer. This should work.
Nov 21, 2009 | Belkin (F5D7633UK4A) Wireless Router
Belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin wireless 'N' with Vonage router and cable ISP modem...
Hi, since your Internet source is the ISP modem, you have to connect the cable from it to the yellow connector of Belkin router, then you can connect the VoIP router and computer to any of the ports (connectors) labeled 1-4 , remember to restart clients (PC & VoIP router) to get the new IP from Belkin router.
Nov 07, 2017 | Belkin (F5D8231-4) Wireless Router...
Cant get router to access internet
The easiest way to set up this router is to connect it via ethernet cable and then access the router with the default ip address and configure it from there
Dec 08, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link dsl-2640b
see
http://www.smallbusinesscomputing.com/webmaster/article.php/2248681
The first answer seems to address your question however as noted in your article the mode you have is not on AOL's recommended however it does support PPPoE so it may (should?) work. I recommend setting it up and getting it to work with a computer wired to the router before configuring and testing wireless connections. In terms of wireless configuration see
http://www.fixya.com/support/t281214-wireless_security
Dec 01, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
