Question about IBM ThinkPad T60 Notebook
Nothing happens when I press the power button except the light
As I said before I spilled some liquid on the keyboard and I let it dried for a few days. The problem still exists: when I press the power button, nothing happens except the light on the monitor screen (the "night light") is on. Now I figure that there's something happen in my laptop coz it's warmed; but the whole thing doesn't really seem to be turned on.
    Scholar:
  • 188 Answers
Regardless if you don'r feel comfortable taking the comouter apart it needs to be taken apart and looked at. Depending on what got spilled inside the sooner the better. If it was a soda of some kind it could be bad.I would take out the battery and not try it again.
Posted on Oct 03, 2008
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Tip
Liquid spills
Todays notebooks & laptops come equipped with spill resistant keyboards. Thats a big help in itself. But some are not . If your notebook has suffered a liquid spill while its on , IMMEDIATELY shut it down. GET AWAY from carpeting or metal furniture or objects: stand on wood or cement floor only. Turn the unit and place on its side to drain it from the liquid (NOT UPSIDE DOWN) and to avoid further damage to mainboard and keyboard. DO NOT TURN IT ON AGAIN  . Remove the battery, hard disk drive, CDROM, memory modules, remove back cover, until exposed to mainboard. Take conventional hair dryer, blow dry using HIGH heat, slowly move over peripherals and mainboard  five inches away with  Extra drying process on keyboard and mainboard. Using a few cotton balls, pat down any excess liquid by absorbing into cotton -- blow dry this area intensley for long time (20-35 minutes, depending on amount of liquid spill). Wait a few days , replace all parts and turn on notebook.
on Jan 21, 2012 | HP Computers & Internet
How do i know if a motherboard is burned out after a liquid spill
what liquid was spilled into the keyboard ? water will dry out in a few days, but if it's soda then the motherboard/cooling fan will have to be cleaned
Jun 10, 2012 | Dell Inspiron 15R Laptop
I spilled liquid on my HP Probook 4320S (with spill resistant keyboard). Dried it up straight afterwards. Now it won't power up
Take it to a service shop asp, key board will need to be replaced, and the laptop will need to be assessed for motherboard damage.
May 06, 2012 | HEWLETT-PACKARD ProBook 4320s C Notebook
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
I accidently spilled a shot of whisky
If you do not have spill proof keyboard, usually, the liquid will go through the keyboard to the motherboard of the system. most likely, you will have to get the motherboard of the system replaced. if the system is still under warranty, call the manufacturer for replacement.
Hope this helps.
May 11, 2010 | Acer Aspire 5315-2153 Notebook
My return key is not functioning on my apple keyboard.
Buy a new keyboard. They are cheap. One possible solution is to allow the keyboard to thoroughly dry and try it. You can pry up the key and look and see if it needs to be dusted out with some air, or cleaned of whatever was spilled on it. Perhaps alcohol on a Qtip on the moving parts. Not sure what "something" splashed on it. Root beer? Water? Big difference. I would visually inspect, try to dust, then clean with alcohol. Let it dry thoroughly and give it a shot. Short course, buy a new monitor. Good luck.
Mar 30, 2009 | Apple Macintosh Keyboard
Need to restart Logitech external keyboard after spilling coffee
If no operation after a few days the liquid did permanent damage to keyboard. Not uncommon.
May 08, 2017 | Logitech 9675020403 Keyboard
Keyboard Malfunction
I suggest you to remove battery.
If this is still not working, your keyboard or motherboard is bad.
Did you spills any liquid on your keyboard ? if you did, probably only your keyboard.
From your explanation, i suspect it's motherboard.
Jul 21, 2008 | Acer Aspire 3050-1733 Notebook
IBM ThinkPad T60 Notebook Logo
257 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
