Question about Bosch Kitchen Ranges
We have just replaced the interface board on our Bosch oven model # HGS7282UC-01. When we put the oven to preheat it stays on for about a minute and then shuts off and shows an error code 160. Can you tell me what this code is and how to fix it? Thanks.
  • 2 more comments
  • aursich Oct 03, 2008
    The oven was turning on and off by itself and beeping constantly also the oven light would go on by itself. It mostly did this when the oven was heated but also at times did it when the oven was not in use. At that time it showed other error codes such as code 120 and 125. We were told it was the interface board and there have been quite a few problems with this due to the heat from the oven going directly up into the area where the interface board is housed.
    Now that we have put the new board in it does sound like a fan is on when we try to heat the oven. It was not doing this beofre.
    Great. Thank you for your help!
    The solution weas very helpful. Thank you.
  • 41 Answers
The tangential blower fan in the top rear has an RPM speed sensor on it. The sensor sends a pulse to the control board at each revolution. If the control board detects that the pulses are coming in too slowly, it will show error 160. The blower may have too much friction in its bearing(s). I took the outboard white plastic bearing off (behind the red rubber) and cleaned it with a Q-tip. I also scraped some deposits off of the metal blower wheel shaft (need a strong magnifier to see this). Then I added light machine oil to the felt oil sponge at the bottom of the hole in the bearing. The blower then ran much faster, and no error!
Posted on Apr 28, 2017
    Master:
  • 479 Answers
For what problem did u replace the board
Posted on Oct 03, 2008
  • tech gurus Oct 03, 2008
    there is a casing stat which senses overheat. this can be due to lack of ventilation if a built-in type or a fault with the fan
    the which u say -- error -160 indicates faulty fan or in a very rare case its a heating temprature control sensor which is faulty whic inturn stops the fan and shows the fan error.but according to me the more chances are of a faulty fan
Ran the self cleaning cycle and now the preheat light will not turn off when it gets to the temperature I set it to. It just keeps preheating. Example: I set the oven for 375. It seemed like it had been...
Sounds like a circuit board issue. If in Warranty, contact the manufacturer and have the controller replaced. A routine cleaning has noting to do with the normal operation of the baking or broiling function. Cleaning is disengaged after the door is unlocked and ready for general aplications.
Feb 20, 2014 | Ovens
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
Oven takes twenty minutes to preheat to 375. Otherwise it works fine.
HI. In order to assist properly, i will need the entire model number. This will insure that any information given will be directed to the correct unit type.
Oct 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
While runing the clean cycle on my 2 day old bosch hgs7282uc gas range, it came up beeping error code 120 after an hour or so of it running.
I PURCHACED A BOSCH HGS7282UC GAS RANGE 6 MOS AGO. THE DOOR WONT CLOSE TIGHTLY,THE HEAT ESCAPES AND HAS MENTED MY KNOBS ON THE STOVE
Apr 29, 2008 | Bosch Kitchen Ranges
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Oven will not light - get F1 code
Your touch pad or control board is bad.
To determine what is bad, disconnect the ribbon strip to the board.
If you receive a code replace the board.
If no code appears, replace the touch pad.
Jan 23, 2008 | Magic Chef CGR3742 Gas Kitchen Range
Kitchen Ranges Logo
1,103 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
