Question about Dometic RM2652 Refrigerator
Refrigerator not working
Frig was working fine. After recall modification was performed (by a dealer) the frig won't work. There is no power light, auto light doesn't come on. Light inside the frig comes on when you open the door. won't work on gas either. Dealer says the power control board is bad. But is there a reset button? I fought for a week to get the dealer to admit he is responsible here.
  • 2 more comments
  • jafaver Oct 04, 2008
  • sallyfixit Oct 22, 2008
    I have the exact same problem. What was the fix?
  • Anonymous Dec 30, 2008
    Our problem is the same we have a light on inside but will not cool. We had ours recall service done and then came home and got it ready for the winter never checked to make sure it was working properly. We are ready to go to FL for the winter and the fridge is not working.
  • dfp2dep Jan 27, 2009
    Problem Solver:
  • 19 Answers
LOWER CIRCUIT BOARD
The controls for Models RM2612, RM2812, RM2652 and RM2852 are unique to these models. They
are NOT interchangeable with any other models.
If you suspect mismatched part numbers, compare the part numbers on parts to the ones listed below
to ensure a proper match.
The RM2612 with Serial Number 41900000 or higher will have Version III controls as original
equipment.
The RM2812, RM2652 and RM2852 should have only Version Ill controls as original equipment.
VERSION I
Display Panel 2932189.01
Power Module 2931842.02 or 2931842.03
Thermistor 2931863035
VERSION II
Display Panel 2932189.02
Power Module 2931842.02X
* Power Module has red plugs and a Red Dot on
the cover.
VERSION Ill
Display Panel 2932189.03
Power Module 2931842.04
Posted on Nov 18, 2008
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator...
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
Oct 11, 2013 | Dometic RM2652 Refrigerator
I have a GSL25JFPA BS that the frig side will not cool properly. Repalced the mother board. t stat in freezer and thermistor in frig. Freezer works fine. Damper will open when first plugged in but closes...
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Jul 06, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Nowater from dispenser new frig..
If it's new (under one year old) then it's Whirlpool's problem.
Call your selling dealer or Whirlpool factory service.
Should be a free call.
If over a year, post back.. Jack
Nov 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light bulb flickers and strange sound
that is just a small problem..try check ur bulb..maybe its loose,tighten it back..then that strange sound maybe came from spark between the bulb and its connection..
Sep 18, 2009 | Whirlpool GS5SHAXN Side by Side...
Dometic 2652 runs sparatically, then quit
If the burner area is geting hot its has a leak
Dec 11, 2008 | Dometic RGE400 Top Freezer Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Dometic frig 2852
There was a recall on the frig by Dometic.
Aug 28, 2008 | Refrigerators
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
Dometic RM2652 Refrigerator Logo
1,506 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
