Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
Luke Posted on Dec 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will start with choke up and will run for about one minute
Fuel pump is working but it seems to not be getting fuel through carburator
George Dubbs
Level 2:
Sergeant:
  • Expert 406 Answers
  • Posted on Nov 08, 2014
George Dubbs
Expert
Level 2:
Sergeant:
Answers
406
Questions
Helped
134302
Points
928
Sounds like the filter may be plugged up..not expensive change it see if that helps..good luck..
1helpful
Outboard troubleshooting. I have a 75 hp Mercury with 2 carbuerators. Serial # 6559142 it's around a 1989 model.. Problem= tank bubble pumps up tight...sits for a minute and gets soft...when I pump it up...
Sounds like the fuel pump isn't working, you can buy service kits though quite often corrosion will prevent you from removing the valves.. or it could simply be the fuel cap isn't venting, remove fuel cap and see if the engine continues to run!
Mar 18, 2017 • Boating
2answers
VTX 1300R 07 ran out of gas and won't start, put fuel in it.
Does your bike have a petcock?
If so you have to prime the fuel bowls with gas by opening the pet **** for a minute until the fuel bowls are full of fuel THEN you set your choke if you have a manual choke THEN start the bike.
2helpful
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
My 2000 Jimmy won't start, I can hear the fuel pump running and then shutting off before I attempt to start the engine. I also hear it running while I attemp to start the engine. The engine won't start...
The pump is working normally the reason it stops before you start the engine is it has built up enough preasure and cuts out. When you turn over the engine it starts up again as the preasure goes down when the carburator open's. The pump only helps the fuel from the tank. It seem's like dirt in your carburator. The reason it wont start after 3 minutes is the excess petrol in the carburator has evaporated hence need to pour more in. Check all pipes filters and carburator for dirt.
2answers
2004 Honda Shadow Aero stalls
sounds like bad fuel try adding some fuel stabilizer.
2helpful
Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
1helpful
2answers
Choking and stalling while running and then will not start
Might be dirty fuel filter change the fuel filter see how it runs.
Top Briggs & Stratton Tools & Hardware - Others Experts
CJ Rock
CJ Rock
john h
ADMIN Andrew
ADMIN Andrew
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
