Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Remote control for fan 836374
The lo button on the remote does not turn on fan. all other buttons for the fanwork.
Fan buttons work the light. Light button does nothing. No button causes fan to operate. What's wrong?
If there are pull-chain switches on the fixture, their operation may have caused remote control to fail. Turn off power at the source, pause for a few minutes, and turn on power. Either fan or light control, or both, may work. If not, you will have to figure out which pull-chain operation makes things right again. To avoid future problems, disconnect the pull chains at the link so only the remote controls operation.
Apr 17, 2016 | Hunter 27185 Fan Speed and Light Control,...
How does the lighting dimmer work on my remote
The low/med/hi buttons work the fan motor. Push and hold the light button to get the dimmer working. All the light bulbs come on at the same time.
May 25, 2015 | Hampton Bay Dryers
My remote lights up when you press the button but it's not controlling my fan.
Controlling a ceiling fan/light using a wall switch causes the remote control to lose its memory. You will have to start all over at the beginning. Remove batteries from the remote, push all buttons to eliminate a stuck button as a cause, then reinstall batteries but do not push any button yet. Be sure all wall switches are off. Go to the power source for the fan/light (not the wall switch) and turn it off. Wait briefly, then turn on the power at the source again. Try remote operation. If successful, use only the remote to control operation. Forget about using the wall switches.
Dec 21, 2013 | Dryers
Directions to reprogram hunter 952g
You need remote control.
Go to your circuit breaker or fuse box, and turn off the power to the fan you will be programming.
  • 2 Turn the fan's remote control over, and remove the battery compartment cover. Take out the remote's 12-volt alkaline battery, and set it aside.
  • 3 Match the DIP switches inside the remote's battery compartment with the DIP switches on the fan's receiver unit.
  • 4 Reinsert the 12-volt alkaline battery into the remote's battery compartment, and replace the battery compartment cover.
  • 5 Go back to your circuit breaker or fuse box, and turn the power to your fan back on.
  • 6 Press the "Hi," "Med" and "Lo" buttons on the remote control in quick succession. Complete this step within 20 seconds of completing Step 5. The remote is now programmed and ready to operate your fan.
  • Sep 06, 2012 | Hunter Dryers
    Need manual for harbor breeze fan model # LP8063
    The remote went bad, this is very common. These are great fans with poor design and cheap remotes. Go to Lowe's buy the new kit ( model: RCE-103LW) $30 bat included. Put battery in and turn off light switch. Have a bic pen ready with the battery cover off. Turn on light switch and press "learn" red button with the pen . You will have to hold it down for about 5 secs. The fan will the turn on medium if it took to learning the new remote. All buttons should now work normal. Return old remote to store for exchange they have a 1year return to to store warenty per the company rep. Anyother problems call 1 800 527 1292. They have good cust. Service.
    Jul 21, 2012 | Dryers
    Hampton Bay Fan will not turn on.
    on some you hold down a button on the remote control while you turn power on .. you keep the button pressed for maybe 20 seconds .. i dont remember what button but probably fan on or light on .. the receiver acquires the code from the remote .. if you still have trouble i can probably find the specific instructions ..
    Jun 05, 2010 | Hampton Bay 54 In. Dawson Ceiling Fan in...
    Penguin model 610012-001a/c compressor won't start
    I would check to make sure that the control is sending the "cool" signal to the control unit. LO on the room temp display usually means that the fan speed is set to low. Is LO and Auto showing on the display at the same time. Try resetting the thermostat first. Hold down the Mode and Zone buttons with the tstat off. While holding them down, turn the tstat back on and hold the buttons down until FF appears on the screen. Release the buttons and try the AC.
    If this does not work, on the control board is a freeze control switch plug (blue usually). Try unplugging this unit and insert a small jumper wire. If the Compressor comes on and runs then you have a bad freeze control switch. If not, then you should replace the control board.
    Hope this helps,
    Jeff
    Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
    Remote controlled ceiling fan
    unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
    Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
    '88 Camry AC buttons not working
    fan speed controler could be bad, fan motor rellay could be bad.
    Apr 14, 2009 | 1988 Cadillac Sedan DeVille
    TV CODES
    tengo un control remoto universal GH RC84912 nesecito los codigos l para un televisor philips me lo pueden enviar a mi correo danielesteban_30@hotmail.com de ante mano gracias
    Dec 11, 2007 | GE JASRM24912 Remote Control
    Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
    Top Universal Remote Control Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
