Question about Epson Stylus Photo R320 InkJet Printer
Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
I've been using this printer for two years and have always had some difficulty getting the CD tray set properly so it will print. It starts the process and then shows an error message, "remove tray, reinstall and push maintenance button" Have tried several times and it just won't print.
  • YakuPrincess Oct 03, 2008
    Thanks very much for your response. I solved it by pushing on the tray slightly. After it positioned itself, the printer seemed to be trying to pull the tray into place to print but it wasn't moving. When I gave it a little push, it slipped into place and printed. Will remember that in future. Thanks again!
  • HoneyTiger Oct 18, 2008
    I have the same problem and I have had to give the cd tray a slight push for the last few years tio get it to feed. Now however, when it feeds, the tray comes all the way forward and will not move back to print. It does the same thing for paper - moves the paper an inch or so, then stops and won't print.
    Is my printer finally a goner?
  • 1,124 Answers
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Posted on Oct 03, 2008
I have an Epson Stylus PHOTO R320, prints fine except when I try to print on a CD. I have windows 7 64 bit. I downloaded all the drivers for that and as I said it prints fine except when I want to p
My research shows that you must use special printable CD/DVD media which generally costs a bit more than nonprintable media. Possibly that is the reason. You don't give much info on what happens - if it feeds and the result is blurry I would think it is the media.
Jan 04, 2015 | Epson Stylus R320 Digital Photo Inkjet...
I keep getting the close the cd/dvd guide
When you flip the main cover up, and flip the CD/DVD tray down, look at the cartridge color guide label (the colored dots). See the LIGHT CYAN dot? Directly across from that dot around underneath the gray cover is supposed to be a little plastic fin. That fin pushes the sensor switch in the CD/DVD tray to let the printer know if it is open or closed. If it breaks off, then the printer always thinks the tray is open. If it's broken off, you will have to either stick a toothpick or something into the switch, or glue a new thin piece of plastic in its place.
Mar 01, 2010 | Epson Stylus Photo R320 InkJet Printer
The cd/dvd tray is not set correctly.
reload the cd/dvd tray then press the maintenance button
Feb 16, 2010 | Epson Stylus Photo R320 InkJet Printer
Epson R265 the disc print tray keeps jamming
did you align the track? check the tray for any cracks, when you try to print cd's make sure that the printer and cd are balanced in a horizontal or even manner
Sep 12, 2009 | Epson Stylus R265 InkJet Photo Printer
The color on my photo is blue on Epson printer R320
This is a common issue when printing using windows software, especially XP since SP2, my advice is always use the Epson software to print. Hope this helps
May 27, 2009 | Epson R320 CD / DVD Printer
Epson Stylus Photo R320 - How to print to inside hole of DVD
In Epson Print CD program go to File ->Inner/Outer Diameter Settings. Set the inner diameter to the size you want.
Nov 22, 2008 | Epson Stylus Photo R320 InkJet Printer
Printing on cd/dvds
you have to change the tray before you turn the unit on.
then check the paper path settings that you are selecting in the preferences. it should say CD/DVD on it, as well as the media type
Sep 05, 2008 | Epson Stylus Photo R320 InkJet Printer
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
306 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
