Question about D-Link DP 300U (DP-300U) Print Server
Having to reset (unplug) daily
Our D-Link DP 300U print server has been working flawlessly for 5 years--recently we are having to reset (unplug) it several times a day to get documents to print. The printers have not changed. What's going on? Is it worn out?
    Problem Solver:
  • 15 Answers
Check the Printer spool service. If documents are getting increase in que, restart the Printer spool services. It will definatly solve your problem.
Posted on Oct 03, 2008
Can't find my usb Printer on my D-Link DP 300U (DP-300U) Print Server What to do anyone
ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
Oct 13, 2011 | D-Link DP 300U (DP-300U) Print Server
Can't reset password D-link DP-300U
Can anyone tell me, what IP Address when reset to default? thx's...
Sep 05, 2009 | D-Link DP 300U (DP-300U) Print Server
DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
There is no reset button
dear
Better way when you take new dp 300u unit in box cd in cd admin software run you can reset button is there please check
May 11, 2009 | D-Link DP-300U (DHDP300U) Print Server
DP 300U
DP 300U's can get be pretty uncooperative when attached to a different router. One solution is to reset the DP 300U to its factory settings. Use the PS Admin software to do this. (If you lost the PS Admin software, you should be able to download it from the internet.) If the software prompts you for a password and you do not know it, try "SYSXXXX", where XXXX is the last four digits of the MAC address located on the underside of the print server.
After you reset the DP 300U you will need to set it up from scratch, a process which is not particularly intuitive. Refer to your "Quick Install Guide" (download it from D-link's web site if you don't have it anymore).
Oct 17, 2008 | D-Link DP 300U (DP-300U) Print Server
Configuring a Mac Book Pro laptop with a DP 300U Print Server
I connected my HP5MP to the DP-300U LPT1 port.
I configured my port on the DLink Configuration tab, giving it a name "hp5"
...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
On my Mac, I go to System Preferences > Print & Fax
Click the + to add a new printer
Select the IP option
Choose the Protocol: Line Printer Daemon - LPD
Type in the Address: 192.168.0.10
Type in the Queue: hp5
Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
and find the driver for your HP LaserJet 5MP.
Save it. Works like magic. ;-)
If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
D-Link DP-300U Print Server Problem:
So... you've messed up the IP address on your DP-300U and now you can't even access the web browser configuration page? Yes, it's happened to the best of us. Although I'm sure there are more elegant solutions, one fix is to reset the server to its factory settings and then reconfigure it from scratch. Given that there is no reset button on the DP-300U, resetting can be frustrating, especially if it's asking you for a password that you never created in the first place! Here's what you can do...
1) Install the psadmin software which came with the print server. If you lost the software, you should be able to find it on the web somewhere.
2) Start the software. It should automatically locate your print server.
3) Click on "factory reset". If it demands a password, and you don't know it, try "SYSxxxx" (where xxxx is the last four digits of the MAC address written on the underside of your server)
4) Dust off your Quick Install Guide and go through the unintuitive configuration process. If you no longer have your Quick Install Guide you can find it on D-Link's website.
Aug 06, 2008 | D-Link DP-300U (DHDP300U) Print Server
DP-300U revB and KONICA MINOLTA bizhub 163
I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
http://support.dlink.com/products/view.asp?productid=DP%2D300U#apps
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
May 10, 2008 | D-Link DP 301P (DP-301P) Print Server
Dp301p+ psadmin password was forgoten
Problems with your D-Link DP-300U LOST IP If you’re like me, you have a ton of computer **** laying around your house. Today I found an old D-Link DP-300U print server laying around and thought that I could put it to good use. The bad thing about these things is the fact that they do not have a hardware reset button on them, so if you forget the IP or the Password, you’re pretty much hosed… or so I thought. After doing some google searches for how to find a lost IP, I came back empty. The PS Admin program that D-Link publishes for use with this thing couldn’t find it on my network either. After some thinking, I came up with an idea.
If you know anything about networking and how networks work, you should have thought about this too. Get a Wireshark capture running. Unplug the power from the print server and then replug it. It’s going to send out an ARP on the network looking for it’s gateway which should be picked up by Wireshark. It should look like this:
capture.jpg In my case, it came back as 192.168.1.253. After changing the IP on my laptop to fit that subnet, I was able to log into it via it’s web interface (there was no password on it thank God!) and put it back to factory settings. Voila! What once was a brick is now a working print server!
I Copied it!
Shafiuddin Russel
infoshafi@gmail.com
+8801714073692
Feb 16, 2008 | D-Link DP-300U (DHDP300U) Print Server
D-Link DP 300U (DP-300U) Print Server Logo
212 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
